PSC34: Rebedding deck hardware and awlgrip deck - Page 2 - SailNet Community
 2Likes
post #11 of 12 Old 09-15-2019
Re: PSC34: Rebedding deck hardware and awlgrip deck
Originally Posted by Markwesti View Post
Over the years I have used Boat Life for bedding with mixed results . My last bedding project I used 3M 4200 , the leak is still there . No fault of the 4200 I'm sure , gotta try it one more time . My latest leak is in my main sheet traveler where it screws down , so I have to be able to shoot the compound down the hole and then screw in the screw .
Are you countersinking the holes? You should, really helps.
Markwesti likes this.
MarkSF is offline
post #12 of 12 Old 09-16-2019
Markwesti's Avatar
I don't know if the hole is c'sunk . It's a factory job that that was installed round 79' I see evidence of stuff not c'sunk on the boat ( a small spider crack coming from something that was screwed down ). So anyway like I said the leak is on my main traveler , there are about 20 other screws that are not leaking so I'm motivated to get just this one hole fixed . If I must remove it I will for sure c'sink .
Westsail 28 , Patricia A
Markwesti is offline
HTML code is Off
