Rudder-post bushing? - SailNet Community
 1Likes
  • 1 Post By Davil
post #1 of 9 Old 2 Weeks Ago Thread Starter
I have dropped the rudder on my 1986 PSC 37 and need help figuring out what is going on. The top of the rudder-post fits inside of a glass tube that comes up to the bottom of the cockpit seat. The top of the tube is accessed from the round bronze plate. Is there some sort of bushing that fits in there or does the ss rudder-post just rotate inside of the glass tube? There is only about .1" difference in the outer diameter of the ss rudder-post and the inside diameter of the glass tube. There was a very worn thin metallic sheet of some sort that fell out of the mix when I pulled the rudder but I am not sure what it is, where it came from, or what it is made from. Anyone else with a similar vintage boat been through this?
Thanks
Grant
s/v Vinandante
granche1 is online now
post #2 of 9 Old 2 Weeks Ago
bristol299bob's Avatar
Re: Rudder-post bushing?
Did you contact PSC? I don't own a PSC but I have dealt with them and they are great, super helpful, super knowledgeable.
Pacific Seacraft
Post Office Box 189
Washington North Carolina 27889
252 948-1421
1977 Bristol 29.9
Surprise
Hull #5
Oriental NC
bristol299bob is online now
post #3 of 9 Old 2 Weeks Ago
Hi
I do not have a specific answer just a comment;
On my return leg Halifax to Cape Cod, I experienced rough weather and when the winds picked up and extreme heeling started to fill my bilge with seawater.
The cause?
a leaking stuffing box at the top of the rudder post!!!! that on extreme heeling was under the waterline.
News to me having a stuffing box on a very hard place to check and service.
I believe this was the most neglected maintenance item on my Cape Dory 30 MK II.
Now I learned.
My old Tartan 34 believe had your setup with only a bushing on the top but the end of the glassed tube was very high on the cockpit and did not have a gland.
cheers
wsmurdoch likes this.
Davil is offline
post #4 of 9 Old 2 Weeks Ago
captflood's Avatar
GREETINGS EARTHLINGS ; You may want to use a nylon bushing if you do make sure it is made out of CAST Nylon not spun as the water proof properties are better with the cast AS ALWAYS GO SAFE
captflood is offline
post #5 of 9 Old 2 Weeks Ago
dadio917
dadio917's Avatar
On our 97 valiant, there are 3 "bearings". The top and bottom (gudgeon) are both a metal, bronze I believe, and take the majority of the load. In the middle of the shaft as it comes in the hull there is a glass housing that contains a third bearing and a packing gland on the top of the glass. From what Valiant tells me this center bearing is synthetic "soft" material that is not intended to be replaced. If it should fail, which they've never heard of happening, the glass would have to be cut out and completely rebuilt. They also said there is a synthetic washer between the rudder and that center bearing housing. This might be similar to what you had fall out.
Valiant still has the blue prints for all vessels they built. Since PSC is such a reputable company I suspect they would as well. So I second a call to them. Hope that helps.
Dadio917
Valiant 39
dadio917 is offline
post #6 of 9 Old 2 Weeks Ago
Location: The house is in Kingsport, TN. Boats are on Watauga Lake and in New Bern, NC
My Pacific Seacraft 34 is tiller steered. My rudder post (rudder shaft) is a metal tube and turns inside a fiber glass tube. In my case there is nothing there but the tube. I have a grease nipple under the seat that lets me shoot grease into the annulus. The boats with wheels have a seal on the shaft that my boat does not need. I too have removed the rudder, but I never saw anything in the annulus but grease. There are a number of threads in this forum about the rudder that can be found with the search function.
Bill Murdoch
1988 PSC 34
Irish Eyes
wsmurdoch is online now
post #7 of 9 Old 1 Week Ago
We just dropped the rudder in preparation for replacing the propeller shaft and cutless bearing in an effort to stop a serious vibration and whine issue. On our tiller steered boat the shaft is 38 inches long measured from the top of the fiberglass rudder blade to the top of the shaft, so that is the distance that the rudder must drop to come out. There is nothing inside the tube in which the shaft turns except grease.
Bill Murdoch
1988 PSC 34
Irish Eyes
post #8 of 9 Old 1 Week Ago
deisher6
Windrunner was upgraded from wheel to tiller by Pacific Seacraft. There is a stuffing box between the stern tube and an keyed "quadrant". The quadrant is more just of a lever arm to attach the auto helm. The rudder post then terminates above the stern seat in a bronze, hard rubber, and starboard like material fitting that is bolted onto the seat with four bolts. The rudder post is then capped off with the tiller. The bronze fitting acts as a bearing.
Your boat is obviously set up a little differently with a stock rudder system.
I think that PSC is currently replacing a pedestal with a tiller, Thumper may have additional information.
I hope that this information helps in some way.
regards charlie
Windrunner PSC-34
post #9 of 9 Old 1 Week Ago
I pulled my rudder for repair and to change out the prop shaft, cutless bearing, etc. winter before last. I don't recall finding any thing like what you show in your photo. Just a tight fit at the top of the rudder post. It looked to be a bronze sleeve of some sort (if memory serves).
-- Bill
"Belle Voile"
PSC 34
elliowb is online now
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
granche1
HTML code is Off
