Pacific Seacraft 40 Anodes - SailNet Community
post #1 of 9 Old 02-23-2010 Thread Starter
I am a new owner (to me) of a PS 40. I have one anode on the maxprop, and one small teardrop on the gudgeon. Is this sufficient? How long can I expect them to last before requiring replacement? Any thoughts and advice welcome.
Avocette is offline
post #2 of 9 Old 02-23-2010
ralopata's Avatar
Our experience aboard JUNO (PSC 40 -- #46) is that the life of the zincs seems to depend a great deal on the nature of the waters where the boat is (i.e. ocean vs. estuary, marinas vs. anchorage or mooring).
Generally, the MaxProp anode is eaten rather quickly -- every two or three months. The gudgeon anode seems to be more long-lived -- a full eight-month season.
In terms of advice, I make a practice of checking the MaxProp anode periodically going over the side with a mask. It is possible to change it in the water as long as you're careful with the retaining screws. The only other MaxProp advice I'd offer, as has been discussed in other threads, is to use an appropriate zinc antifouling (MaxProp recommends a Pettit product) on the prop as barnacles tend to find the props very attractive for some reason.
Best of luck with your new boat.
Roger Lopata
JUNO
PSC 40 -- #46
ralopata is offline
post #3 of 9 Old 02-23-2010
MC1
Originally Posted by ralopata View Post
. . . In terms of advice, I make a practice of checking the Max Prop anode periodically going over the side with a mask . . .
. . . and of course it goes without saying . . . not at the marina if there's shore-power due risk of electrocution.
MC1 is offline
post #4 of 9 Old 02-23-2010
teejayevans's Avatar
I tape a wire to the propeller shaft and attach it to a zinc hung over the
side, plus with galvanic isolator, I can get a year out of them when in salt
water, 2 years when in briny water.
Tom
PS31#111 Cielo Azul
teejayevans is online now
post #5 of 9 Old 02-25-2010 Thread Starter
Thanks for the advice, much appreciated.
Avocette is offline
post #6 of 9 Old 08-16-2019
Re: Pacific Seacraft 40 Anodes
We had been burning through the MaxProp zinc on our PSC 40 every 3 months or so in a crowded salt water marina, but after installing a galvanic isolator, the zinc replacement interval increased 2X or 3X. Installed a "ProMariner ProSafe FS Galvanic Isolator - 30 Amp" below the electrical panel.
Jay
Serenade, PSC 40 #14
jaybo_nomad is offline
post #7 of 9 Old 08-17-2019
I don't discuss my member
Fstbttms's Avatar
That's really only an issue in freshwater.
Fstbttms is offline
post #8 of 9 Old 08-17-2019
I hear, if one suffers from electric shock drowning, they can be resurrected 9 years later.
Jeanneau 54DS
Minnewaska is offline
post #9 of 9 Old 08-17-2019
Location: The house is in Kingsport, TN. Boats are on Watauga Lake and in New Bern, NC
As Fstbttms said, "That's really only an issue in freshwater."
From https://www.electricshockdrowning.org/esd--faq.html,
"WHAT IS ELECTRIC SHOCK DROWNING?
Electric Shock Drowning (ESD) is the result of the passage of a typically low level AC current through the body with sufficient force to cause skeletal muscular paralysis, rendering the victim unable to help himself / herself, while immersed in fresh water, eventually resulting in drowning of the victim. Higher levels of AC current in the water will also result in electrocution. Electric Shock Drowning (ESD) has become the catch all phrase that encompasses all in-water shock casualties and fatalities."
It happens all the time... https://www.electricshockdrowning.or...nd-events.html
Bill
wsmurdoch is online now
Pacific Seacraft 40 - electrical ground/keel barrier coat failure? rschaedel Electrical Systems 8 10-16-2015 09:32 AM
Aluminum Sacrificial Anodes for "brackish" water??? T37Chef Gear & Maintenance 1 07-31-2009 12:10 AM
Zinc or aluminum anodes for my sailing area? josrulz Gear & Maintenance 5 02-09-2009 09:36 PM
Anodes warwicksail Gear & Maintenance 2 12-28-2007 07:28 PM
Anodes & Corrosion serendib Gear & Maintenance 6 07-30-2006 03:15 PM
HTML code is Off
