chainplate followup - Page 5 - SailNet Community
 1Likes
post #41 of 44 Old 02-07-2016
Location: The house is in Kingsport, TN. Boats are on Watauga Lake and in New Bern, NC
Re: chainplate followup
Originally Posted by jnewcomer View Post
I did investigate having custom, button-head, socket cap screws made but the cost was prohibitive.
One of my favorite merchants is McMaster Carr. Long ago their yellow and green catalogue sat on every maintenance foreman's desk. If you think it should exist, they have it... now on the internet.
McMaster-Carr
Grainger also has them in 18-8.
wsmurdoch is online now
The Following User Says Thank You to wsmurdoch For This Useful Post:
bird song (02-09-2016)
post #42 of 44 Old 02-14-2016
s/v Pelagic
I also use McMaster for many things. However all the bolts in the appropriate length are threaded all the way up to the head. I wanted a smooth 1/2 inch OD on the bolt to go into a smooth 1/2 inch ID on the chainplate. Since I was trying to avoid the point loading of the square carriage bolts I also didn't want the whole load bearing on just two or three threads.
Regards,
John
jnewcomer is offline
post #43 of 44 Old 02-14-2016
Yes you are right, both the photograph and the drawing in the link show a 2" bolt with 1-1/2" threading, but the notes to the drawing say the thread length could be 1-1/2" to full. If the bolts are like the photo and drawing, there would be a half inch unthreaded. If the actual threading were full as the notes allow, threads would bear on the chainplate.
post #44 of 44 Old 02-14-2016
chainplate followup
Regards,
John
In any chain plate installation the bolt should never carry any shearing load. The bolt is used to force the plate against the knee. The pressure creates so much friction that the plate does not move and puts no shear force on the bolt. If the chain plate is allowed to move then only one bolt will be carrying the entire shear load. That's bad for then one bolt will likely shear. Then another and another until they all fail.
Carriage bolts are often used because it's hard to put a wrench on both sides in some situations. The square shoulder is held from turning by the chain plate itself. They should not create point loading.
Transmitterdan
1995 Valiant 42
transmitterdan is online now
Installing New Windows- Followup seb5thman Gear & Maintenance 5 04-24-2010 04:03 PM
chainplate fabrication.. groundhog Gear & Maintenance 3 09-16-2008 10:45 AM
New chainplate insallation Newport41 Gear & Maintenance 9 08-22-2008 08:23 PM
Followup to: I received this from an NBC News feed which comes to NewsReader Mass Bay Sailors 0 09-22-2006 01:15 AM
followup miss/ar/intra weedeater64 Living Aboard 0 09-17-2006 05:39 PM
HTML code is Off
