Holding Tanks with Urine only - SailNet Community
 50Likes
post #1 of 45 Old 5 Days Ago Thread Starter
Moderator
MarkofSeaLife's Avatar
Dock
I'm heading into a marina for 6 months. Pump-out is extremely expensive... like US$31!
I use the 2 heads and holding tanks *only* for urine as the marina bathrooms are close and modern, including for my guests.
Toilet paper goes into a bag.
The marina is small and inside a Lock so using the Holding Tanks is important. The water in the marina is salt.
Theres many products for marine and RV tank biodegradable effluent... but I am interested in any idea/product/chemical that might mean I can flush using less water, and, reduce pipe and tank buildup.
Fresh dock water is free, so I was wondering if theres any benefit to using fresh to flush?
Thanks
Mark
Sea Life
Notes on a Circumnavigation:
People can say they want freedom, but offer them the keys to what chains them, a map to where they want to go,
And they'll turn it down for the cell they know
MarkofSeaLife is offline
post #2 of 45 Old 5 Days Ago
Master Mariner
capta's Avatar
Re: Holding Tanks with Urine only
Two problems come to mind.
If you hook up your heads to your fresh water system, back flow is possible, contaminating your fresh water system. Second, most salt water marine heads are not set up for pressure water rinsing, so this could damage the mechanism. I'd contact your head manufacturer and see what they have to say about it.
chef2sail and MarkofSeaLife like this.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #3 of 45 Old 5 Days Ago
bell ringer
Don0190's Avatar
I have the cheapest jabsco head available. When I'm in a marina I always use fresh water to flush with and just keep a cup in the head get water from the sink to pour flush into the bowl. I assume You can flush some acid down the line once in a while also to remove the scale.
MarkofSeaLife likes this.
Don't blow air up my rear, be useful and blow it at the sails!
Don0190 is offline
post #4 of 45 Old 5 Days Ago
It sounds like you're wondering if you can flush less clear chase water and leave urine in the waste lines and whether fresh water would be a better idea. I understand that salt water is more likely to react with urine than fresh, so perhaps fresh would reduce scale build up. Fact check that one.
Nevertheless, I don't think it's wise to do for 6 months, even with fresh. Waste left in the lines, even urine, will eventually permeate. I understand that pushing through sufficient clear chase water really fills a holding tank fast.
Here's an idea. Buy a pilot relief jug for yourself at night, or even during the day. I use one in the shoulder seasons, before marina systems are all commissioned, or I can't get to the pump out. No way I want to walk to the shore facilities at night in the cold. My wife finds it gross, but long distance pilots have been using them forever and urine really is sanitary. They have a lid. Carry it up to the shower in the morning, in whatever bag you pack your clothing and toiletries. You could also have a larger storage bottle aboard, which you transfer to and empty less frequently.
https://www.amazon.com/1st-Defense-I...=fsclp_pl_dp_1
Save your holding tank space for guests.
Jeanneau 54DS
Minnewaska is offline
post #5 of 45 Old 5 Days Ago
Old as Dirt!
svHyLyte's Avatar
Mark--
I don't know where you are situated at the moment but we are in a similar marina environment and have one head that is designed for "urine only" that flows overboard rather than into a holding tank. Urine has virtually no effect on water quality as the dilution is so great. The bowl is used, the reasonably filled with fresh water from the sink tap, then pumped overboard. Once a month or so, flush a solution of a gallon of fresh water with 8 ounces of Muriatic acid through the system and you're fine.
FWIW...
svHyLyte is offline
post #6 of 45 Old 5 Days Ago
Originally Posted by MarkofSeaLife View Post
....The marina is small and inside a Lock so using the Holding Tanks is important......
Originally Posted by svHyLyte View Post
.....designed for "urine only" that flows overboard rather than into a holding tank. Urine has virtually no effect on water quality as the dilution is so great........
I knew this would come up. I'm the first to say that environmental discharge rules are not all scientifically sound. They paint a broad brush, rather than try to detail all the variables.
However, in Mark's case, it seems both inappropriate and a good way to get in conflict as a foreign transient guest.
Jeanneau 54DS
post #7 of 45 Old 5 Days Ago
SanderO's Avatar
What is the impact of one person's urine pumped into the sea? Urine has a role in the earth's nitrogen cycle. In balanced ecosystems urine fertilizes the soil and thus helps plants to grow.
pay attention... someone's life depends on it
SanderO is online now
post #8 of 45 Old 5 Days Ago
I doubt there is any science that proves a small amount of urine, from a recreational live aboard does any harm. I've read perspective from many that human urine can contain chemicals, especially if one is taking meds, that are harmful to the marine environment. I suspect, in most marina, the dilution is still ample, but maybe not in all marinas.
In the end, while I'm okay with some discretion, I wouldn't want to be called out, in what Mark described as a small marina behind a lock, as a foreigner who hasn't been to the pump out in a while, without a pretty good explanation.
Jeanneau 54DS
post #9 of 45 Old 5 Days Ago
Master Mariner
capta's Avatar
I've been looking for over 5 decades for "some acid" or any other product that I could simply flush down the head to clear the ceramic build-up out of the head exhaust lines, to no avail. Got anything specific in mind?
I've used white vinegar to clean head parts and it works to some degree (it takes days), but it does not work well enough to clear the lines significantly.
capta is online now
post #10 of 45 Old 5 Days Ago
Pretty sure studies have been done on all the chemical witchcraft folks pour down their heads for all sorts of reasons and none have proven to actually work. Some do more harm than good.
SanderO and MarkofSeaLife like this.
Jeanneau 54DS
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
SanderO
HTML code is Off
