Assembly drawing for Marinium Fuel cap? - SailNet Community
 1Likes
  • 1 Post By capta
post #1 of 6 Old 4 Weeks Ago Thread Starter
I have noticed that there is about 1/16 gap under the outer aluminum ring of my fuel cap between it and the cockpit floor. When I get water in the cockpit it drips through onto the top of my fuel tank. Fortunately it does not seem to be entering into the tank.
I was looking to see if anyone can point me in the direction of an assembly drawing.
I'm thinking that I can undo the three screws, lift off the outer alum ring, cut a rubber gasket to go on the under side of the ring and re-assemble?
I don't want any surprises when I undo the screws hence my post.
Robert
Rob_P is offline
post #2 of 6 Old 4 Weeks Ago
Re: Assembly drawing for Marinium Fuel cap?
Balsa core? Can you get at the hose under ?
Capt Len is offline
post #3 of 6 Old 4 Weeks Ago
Master Mariner
capta's Avatar
Try this stuff. It was specifically developed to bed things on boats.
oysterman23 likes this.
ďBelieve me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.Ē ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is offline
post #4 of 6 Old 4 Weeks Ago
Can you see why the ring doesn't sit flush? It seems odd to me that there is a gap.
paulinnanaimo is online now
post #5 of 6 Old 3 Weeks Ago
roverhi's Avatar
That's almost a guarantee that the balsa core in the area will be rotted. Don't know how to pull the fill assembly but would do it asap. If the core is bad in the area but hasn't extended far, fill space between the laminate skins with thickened epoxy after cleaning out the immediate area as best as you can. Only need to fill in an inch or so so the outer laminates don't crush together. Caulk with a fuel resistant caulking compound, that's NOT Butyl or Dolphinite which both dissolve in the presence of hydrocarbons.
roverhi is offline
post #6 of 6 Old 3 Weeks Ago
Iím guessing there is already a gasket that doesnít seal well, with the rough non-skid. The trick may be to grind it down or fair it out smooth.
You wonít need a drawing. Remove the hose from below and the three deck screws and Iím sure youíll figure it out.
Jeanneau 54DS
Minnewaska is offline
HTML code is Off
