upgraded pump for pump out cart - Page 2 - SailNet Community
 6Likes
post #11 of 12 Old 10-04-2019
Learning the HARD way...
eherlihy's Avatar
Re: upgraded pump for pump out cart
Originally Posted by capta View Post
First off, no centrifugal pump is going to do that job. You will need a pump that can create enough suction to pull a heavy liquid with some solids up a tube on the boat and then up a hose into a container.
If you can find such a pump for under $500.00 (110vac, not 12vdc) you would be lucky. I'd guess closer to a grand.
Not sure if this was directed at my macerator suggestion, or not. Most macerators (when new) are capable of self priming up to 4 feet (1.3 meters).
USCG Licensed OUPV Captain, US/Sailing BKB and ASA 101/103/104/105/106/114/118 Instructor - Also ABYC certified in Marine Electrical Systems,
eherlihy is online now
post #12 of 12 Old 10-04-2019
Dirt Free
boatpoker's Avatar
If you can find such a pump for under $500.00 (110vac, not 12vdc) you would be lucky. I'd guess closer to a grand. Tell your marina to get off their a$$ and supply the state mandated equipment, not some cheap hand toy. After all, they aren't supplying you with an especially cheap slip, are they?
The 12volt pump that I mentioned in post #9 has been working flawlessly for years can be purchased on Amazon right now for $346.
https://www.amazon.com/Dometic-Seala.../dp/B07G898M44
In marinas that freeze they must shut down their waste pumping operations for the winter. That is why I built the waste cart in the first place.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is offline
The Following User Says Thank You to boatpoker For This Useful Post:
bristol299bob (10-04-2019)
HTML code is Off
