Sea Cocks - SailNet Community
 3Likes
  • 2 Post By colemj
  • 1 Post By colemj
post #1 of 8 Old 11-10-2019 Thread Starter
Sea Cocks
Anyone seen one of these?
Bristol boater is offline
post #2 of 8 Old 11-10-2019
Re: Sea Cocks
If you are sailing a Bristol, most of the OEM seacocks were manufactured by Spartan Marine in Georgetown Maine.
If you want to replace the broken handle, you may find what you need here:
https://www.spartanmarine.com/all-pr...adapters-parts
chicory83 is offline
post #3 of 8 Old 11-10-2019
colemj's Avatar
Re: Sea Cocks
The logo on the handle is Wilcox-Crittenden's.
Mark
ottos and capta like this.
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
post #4 of 8 Old 11-10-2019 Thread Starter
Thanks guys. Trying to track down why they might be frozen/stuck and if there is hope for getting them moving again. In water versus/hauled etc. Now I have a plaxe to start researching!
post #5 of 8 Old 11-10-2019
colemj's Avatar
Re: Sea Cocks
Can't see the valve itself well in the picture, but it is likely a tapered plug valve. If so, these often get sticky or stuck, but they are usually easy to remedy. You will need to free it and remove it, then use some lapping compound like that for valves, and work it back and forth to smooth things out. After that, a bit of grease and it will work easy again. After that, every so often when it is on the hard, regrease. Some people have put zerk fittings in them to grease while in the water.
Mark
tempest likes this.
- Current boat
- Previous boat
colemj is offline
post #6 of 8 Old 11-11-2019
Re: Sea Cocks
One strategy that has worked for me when they are really stuck is inserting a tapered plug outside the hull, removing the hose and then filling the seacock with a penetrating oil like Marvel Mystery Oil and letting it soak for as long as necessary. Be careful not to pound on these too hard as you can crack the casting. The barrels are usually matched to the valves, so you can't just replace the barrel, you have to replace the entire through hull if that happens. The trick to keeping them from sticking is to lubricate them regularly. A good coat of seacock grease can also seal them up if they are weeping a bit.
post #7 of 8 Old 11-13-2019
Seņor Member
ottos's Avatar
Re: Sea Cocks
I went through the same thing last spring on my 29.9. Take that handle off (the thumb screws are certainly not original, and probably corroded) and get as long a wrench as you can fit on there. If it valve is really stuck, you'll just break the handle off anyway.
Gentle heat from a torch can help... (As can penetrating oil, as previously mentioned)
Have you loosened the jam nut and the flange nut on the other side of the valve from the handle?
Study MaineSail's article : https://marinehowto.com/servicing-ta...cone-seacocks/
In the end, I had a really big guy from the yard on a really big wrench break it loose...and smash his elbow when it gave way.
Incidentally they get stuck from lack of exercise and lack of service.
I was happy to be doing that while hauled. It can certainly fail under the strain...
ottos is offline
post #8 of 8 Old 12-01-2019 Thread Starter
Thanks for all the tips. Something to work on next spring..(boat hauled). Going to try disassembly, oil, the works...
HTML code is Off
