SailNet Community (https://www.sailnet.com/forums/)
-   Plumbing, Heads, Water, Bilges etc (https://www.sailnet.com/forums/plumbing-heads-water-bilges-etc/)
-   -   Boat Hatch Replacement (Hardin 45, Voyager 44) (https://www.sailnet.com/forums/plumbing-heads-water-bilges-etc/332114-boat-hatch-replacement-hardin-45-voyager-44-a.html)
VVVN 12-11-2019 11:40 PM
4 Attachment(s)
Hi, all
i had a leaky hatch in the head compartment and i'm trying to find a replacement for it.
- Hatch-hull opening: 14 3/4" x 4 3/4"
- Hatch: 14 1/2" x 4 1/2"
See attached images...
I've tried looking online but in vain.
Any ideas ?
Thanks,
Minnewaska 12-12-2019 09:03 AM
Re: Boat Hatch Replacement (Hardin 45, Voyager 44)
Try Hatchmasters. They sell some, can fix almost anything and know the history and suppliers of everything else.
https://hatchmasters.com/hatch-repair/
Where is the leak? Does it simply need to be re-bed? Hatchmasters can replace glass, if that's the leak.
capttb 12-12-2019 12:00 PM
It looks like a Beckson port to me, check the size 414 which seems to be the size.
https://beckson.com/ports.html
Capt Len 12-12-2019 12:03 PM
It appears that some repair to the cabin side may be necessary .before anything will work.
VVVN 12-12-2019 02:17 PM
Were you able to measure the cut-out opening size? Mine is 4 3/4" x 14 3/4" (see images) - just making sure they're the same cut-outs.
VVVN 12-12-2019 02:18 PM
Yup, you're correct - hopefully i'll manage to get some time in the coming spring.
chef2sail 12-12-2019 02:27 PM
Pay good attention to the surrounding area if there was an issue with water intrusion. It may require some new glassing, core repair if there is one.
I have replaced a couple of ports and it was not difficult. Just make sure the new port is embedded into a good fitting and solid foundation.
Good luck.😄😄😄
VVVN 12-12-2019 02:49 PM
Good luck.😄😄😄
What sealant did you use to caulk it ?
THanks,
chef2sail 12-12-2019 03:14 PM
THanks,
Mainesail has excellent tutorials ( hes a SN member too😀)
Butyl tape
Stay away from silicon
https://pbase.com/mainecruising/nfm_port_lights
pilott 12-14-2019 12:24 PM
I replaced 4 portlights with New Found Metals stainless units. I highly recommend them - great quality, at a fair price. Installation is not difficult - about 4 hours each.
The NFM 14x4" model looks to match your opening
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
