Head Hose Scale - Page 2 - SailNet Community
 1Likes
post #11 of 14 Old 01-10-2020
Re: Head Hose Scale
Surely the most excessive "Barney Fife" approach to a little sawdust, nearby signs do say something like "illegal to allow any foreign objects in water" or some such nonsense. I believe that deputy was reassigned to a less desirable duty station after generating a few negative comments to the newly promoted female lieutenant in charge.
MarkofSeaLife likes this.
"Just call me TB"
capttb is offline
post #12 of 14 Old 01-11-2020
Re: Head Hose Scale
Sounds like a Barney Fife, but for what it's worth, you must use a dust collector at our marina here too. On land or at the slip. I think it's both environmental and to keep anyone from dusting up their neighbors.
Jeanneau 54DS
Minnewaska is offline
post #13 of 14 Old 01-11-2020
Location: The house is in Kingsport, TN. Boats are on Watauga Lake and in New Bern, NC
Re: Head Hose Scale
See the "Wastewater Treatment" part of the Wikipedia article "Struvite". The RV guys complain about it in their holding tanks. Google "struvite removal from holding tanks".
wsmurdoch is online now
post #14 of 14 Old 01-11-2020
Dirt Free
boatpoker's Avatar
Re: Head Hose Scale
I've had ABS pipe (same as most homes) with cleanout ports for 30yrs. Only have 6" of hose at tank and at toilet. Cheaper than sanitation hose much easier to work with for tight turns and easy to get a straight fall to the tank. Run into a problem, open the port, roto it out, all fine again.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
HTML code is Off
