Head Hose Scale - SailNet Community
 1Likes
post #1 of 14 Old 1 Week Ago Thread Starter
bell ringer
Don L's Avatar
Head Hose Scale
I am replacing my basic manual head with a fancy new electric fresh waster unit. I wasn't going to replace all the hose because it wasn't too old and its the expensive hose. But cutting into it to make the connection from the 1” new hose i am using to the 1.5” that goes to the tank this is what i found. This in spite of all the acid i have flushed through that hose over the years. I'm surprised things flush through that old hose. Guess now I know why the other head that doesn't get used much use pumps so much easier even though it pumps uphill. . Hopefully now with only fresh water flush this never happens again.
Don't blow air up my rear, be useful and blow it at the sails!
Don L is online now
post #2 of 14 Old 1 Week Ago
colemj's Avatar
Re: Head Hose Scale
Fresh water will just about solve that. If this was right at the toilet connection, then it might not extend all the way through the hose. PVC pipe also seems to solve the problem. I don't know why it should, but it doesn't seem to form scale deposits as bad as hose.
I can't tell if your sentence "This in spite of all the acid i have flushed through that hose over the tears" was an autocorrect, or exactly how you meant it...
Mark
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
post #3 of 14 Old 1 Week Ago
Moderator
MarkofSeaLife's Avatar
Dock
Re: Head Hose Scale
Yes, its really obvious thats not going to be removed with acid. Let along the vinegar brigade.
If your going to use acid it needs to be done weekly from week 1.
The cost of sanitation hose is ridiculous. utterly stupid. But changing it so often is the only way.
With the diameter reduced by half any visitor will clog it up.
Sea Life
Notes on a Circumnavigation:
People can say they want freedom, but offer them the keys to what chains them, a map to where they want to go,
And they'll turn it down for the cell they know
MarkofSeaLife is offline
post #4 of 14 Old 1 Week Ago
Re: Head Hose Scale
Part of regular care and feeding of a salt flushed head is removal of hoses and whopping them on the edge of the dock.The floppy bits in the pump need dealing with too. the thru hull can be a problem. Fresh water flush mostly prevents it but you have to start clean.
Capt Len is online now
post #5 of 14 Old 1 Week Ago
Moderator
Dock
Re: Head Hose Scale
Your boat must be mch better thn mine, but removing them is an utter pain. and bloodthirsty work too on the knuckles.
I did that once and split the hose. In some dump without replacements.
Never again. Every big haulout I have someone else exchange them. Bliss
They need replacing now. Sooner than the antifoul... but I am in cold water.
Sea Life
post #6 of 14 Old 1 Week Ago
outbound's Avatar
Can occur with fresh water but takes much longer. Using only RO water does prevent it. Also don’t leave urine in it.
s/v Hippocampus
Outbound 46
outbound is online now
post #7 of 14 Old 1 Week Ago Thread Starter
bell ringer
Don L's Avatar
Re: Head Hose Scale
For the amount of work it takes to remove and replace I would never consider taking them out and "whopping" them and putting the old ones back in.
So that took just 20 hours of time and 1 boat buck
Don L is online now
post #8 of 14 Old 1 Week Ago
Re: Head Hose Scale
Watched the Harbor Patrol (county sheriff) tongue lash a dockmate for 30 minutes for using a palm sander without a dust collector on his cap rails. I can only imagine their response to someone whacking hoses on the docks.
"Just call me TB"
capttb is offline
post #9 of 14 Old 1 Week Ago
Re: Head Hose Scale
Iím not doing it. Once I went through the effort to get it out, Iíd put new back in. That said, Iíve seen it done. It didnít contaminate, as the end was plugged. Plugging is always a good idea, as you extract longer length of hose, in the event it contains some settled ďliquidĒ.
I just replaced the standing length on a couple of heads last season. Just the 4 feet or so, up to the vented loop, which holds standing water and is the most likely to scale. Chucked and replaced. Disgusting mess in the head, on extraction. I hate old plumbing more than any other job.
Jeanneau 54DS
Minnewaska is offline
post #10 of 14 Old 1 Week Ago
Moderator
Dock
Re: Head Hose Scale
You're kidding!!
The world has gone crackers!
Sea Life
HTML code is Off
