Hose Permeation - SailNet Community
 14Likes
post #1 of 37 Old 4 Weeks Ago Thread Starter
Hose Permeation
Which hose are people going with to prevent head hose permeation?
post #2 of 37 Old 4 Weeks Ago
Re: Hose Permeation
Sanitation grade hose. There are lesser-quality hoses that look similar to the white sanitation hose, so make sure it specifically says "sanitation."
Damon Gannon is offline
post #3 of 37 Old 4 Weeks Ago
outbound's Avatar
Re: Hose Permeation
Suggests on brand? The stuff is impossible to bend. Tricks using it?
s/v Hippocampus
Outbound 46
outbound is offline
post #4 of 37 Old 4 Weeks Ago
bristol299bob's Avatar
Re: Hose Permeation
I used trident 101 Sani-shield (white): https://www.defender.com/product.jsp?id=1845631
It's very hard to bend, heat is necessary for most bends. For the really tight turns I used PVC elbows. Also hard as the devil to get it over barbs ... heat and pipe lube helps.
1977 Bristol 29.9
Surprise
Hull #5
Oriental NC
bristol299bob is online now
post #5 of 37 Old 4 Weeks Ago
pdqaltair's Avatar
Re: Hose Permeation
If you cannot handle the stiffness of Trident 101/102, Raritan Sani-flex has an excellent record and will go anywhere a hose can. That said, it is so flexible that you can over bend it and create a kink, so don't force it and respect the recommended minimum radius. But it is a joy to work with, including fitting over barbs (KY or glycerine help).
bristol299bob likes this.
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
post #6 of 37 Old 4 Weeks Ago
S/V Caper Nonsuch 36
flyrod's Avatar
Re: Hose Permeation
Trident 101 or 102 (black or white) has a 10 year odor free guarantee, it is a double wall rubber hose with a bacteria (?) scrim barrier between the layers. Very stiff and expensive hose. Raritan has a sani/flex hose that is quite flexible in white with a 5 year odor guarantee, butyl rubber I believe, which has been quite successful. Also quite expensive, but this is a task most don't want to be doing often. Rubber hoses seem to be the most reliable. The best and cheapest would be rigid PVC schedule 40 DWV pipes and fittings which have a short section of good sanitation hose at the head and at the tank to accommodate vibration. The pipe needs to be sized to fit the ID of the hose with the OD of the pipe, slip on with clamps. Good luck.
flyrod is online now
post #7 of 37 Old 4 Weeks Ago
colemj's Avatar
Re: Hose Permeation
The best answer is PVC pipe, not hose.
You have a brand new boat, so probably won't be worrying about hoses for many years.
Mark
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
post #8 of 37 Old 4 Weeks Ago Thread Starter
Re: Hose Permeation
Fountaine Pajot isn't known for using the best quality hose for the blackwater tanks. I'm going to change it before we start out circumnavigation next year.
post #9 of 37 Old 4 Weeks Ago
Re: Hose Permeation
I have used Shields Poly X. It is good stuff, but not cheap.
fallard likes this.
hildamman is offline
post #10 of 37 Old 4 Weeks Ago Thread Starter
Re: Hose Permeation
thanks.
HTML code is Off
