Time to resurrect the Ferrocement yacht? - Page 2 - SailNet Community
 12Likes
post #11 of 25 Old 07-14-2015
Tartan 27' owner
CalebD's Avatar
Re: Time to resurrect the Ferrocement yacht?
Prepper tip: build your plasticized cement pool in the shape of a sailboat hull, complete with ballast. That way, when the waters do rise you just dig out around the pool, throw on a rudder, cabin top, rigging and sail off!
Everybody has one:
CalebD is online now
post #12 of 25 Old 07-15-2015
Closet Powerboater
MedSailor's Avatar
Originally Posted by Rhapsody-NS27 View Post
if it was a DIY job, would it help to consult the guys who spray concrete pools? They tend to spray on vertical surfaces and could give some insight to the issue.
I knew a ferro boat owner who referred to his boat as "an inside-out swimming pool."
Rhapsody-NS27 likes this.
MedSailor is offline
post #13 of 25 Old 07-15-2015
The most female moderator
Donna_F's Avatar
Dock
I've only ever seen discussions of build quality, construction, cost, etc. Never about how they actually sail, maintenance issues while cruising or whatever. I'd be interested in hearing from someone who owns one.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #14 of 25 Old 07-15-2015
jackdale's Avatar
I first saw one at anchor in Turkey. There were red stains along the hull that matched the re-bar.
jackdale is offline
post #15 of 25 Old 07-15-2015
When you can build a far stronger and far less labour intensive steel hull in two days , why bother with cement. If you want something as strong as steel ,then use steel!
I lost my first offshore boat, a ferro cement hull, on a Fijian coral reef in 1975 , in conditions which would not have damaged a steel boat at all.
Gunnite ( spray concrete ) was used in the 70s on some concrete hulls.
Brent Swain is offline
post #16 of 25 Old 07-15-2015
Donna_F's Avatar
Dock
But have the changes in the technology made this type of experience a thing of the 70s?
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #17 of 25 Old 07-15-2015
S/V Calypso
clip68's Avatar
Brent, I think the point is that the newer construction techniques make it a viable alternative again. Steel construction ins't something everyone is prepared to do in their backyard, considering the costs, weight and specialized equipment.
To hear it told by metal boat advocates all the boats made prior prior to the advent of metal construction should have sunk almost immediately, and you are taking your life into your own hands if you use fiberglass or other composite techniques.
IMHO...
The average man will bristle if you say his father was dishonest, but he will brag a little if he discovers that his great-grandfather was a pirate. Bern Williams
clip68 is offline
post #18 of 25 Old 07-15-2015
Old enough to know better
Yea, the concrete might have improved, but that is only a small part of the structure. The bigger issue is that it is a heavy, thick, weak material, even with modern improvements. Ferro-cement is pound for pound the weakest material available. It was only popular as a home boat maker material because of ease of use and price. If I were to make a boat at home I would cold mold it. And the hull is really a small portion of the cost of a boat, so trying to save on the hull cost does not really help much. On top of it very few people have the time anymore to actually there own boat, I think there is likely only a small percentage of the number of home builders there once was. Then add to that the used boat market where you can get a complete ready to go boat for less than the materials to make a hull I really don't see that there is much need for this. Not to mention that the material tends to make poor sailing boats and requires continuous maintenance to keep it looking good.
miatapaul is online now
post #19 of 25 Old 07-16-2015
Doesn't sail enough
zedboy's Avatar
The cost of home-building isn't in the hull, it's in the fittings, and those are the same no matter what you use as a hull. After 60+ years of fiberglass hulls, it will be easier to find a bare glass hull in solid condition and build that up, for larger boats (say >25'). For small boats, I don't think anything beats stitch-and-glue plywood for speed and ease.
zedboy is offline
post #20 of 25 Old 07-16-2015
I can't re Member
That's where the 3-D printer comes in.
goat
goat is offline
Sailing through time with the Presqu?ile Yacht Club (The Independent Online) NewsReader News Feeds 0 07-27-2006 01:15 AM
Ferrocement Pros and Cons Dan Dickison Buying a Boat Articles 0 10-06-2001 09:00 PM
Considering Ferrocement Don Casey Buying a Boat Articles 0 03-22-2001 08:00 PM
Considering Ferrocement Don Casey Gear and Maintenance Articles 0 03-22-2001 08:00 PM
Insuring a Ferrocement Boat Mark Matthews Buying a Boat Articles 0 09-06-2000 09:00 PM
