Amount of lead in fin keel of 1969 C&C 36 ft sailboat - Page 3 - SailNet Community
SailNet FAQ No Posting Please
 4Likes
post #21 of 22 Old 02-13-2019
Learning the HARD way...
eherlihy's Avatar
Re: Amount of lead in fin keel of 1969 C&C 36 ft sailboat
A follow up to post 11 with details:
1987 O'day 35: Keel repair was conducted in 2010. The repair consisted of replacing the 304 keel bolts with 316 stainless bolts which hold the keel to the keel stub. The keel is set on a 1/4"-3/8" bed of 3M 4200. The keel joint was then wrapped with a 6" skirt of fiberglass and epoxy. There is no groove in the stub or the keel, and the 4200 cannot be removed or replaced without first removing the skirt.
This joint does not leak, and the keel does not move. If the keel moved, the glass/epoxy skirt would crack. The only way that water has entered the bilge is via the mast, and when the raw water pump seal failed.
Maine Sail said it best in his post which I referenced in post 11;
IF YOUR KEEL BOLTS ARE LEAKING DO NOT JUST TORQUE THEM. DROP THE KEEL AND FIX IT BEFORE YOU NEED ALL NEW BOLTS!
USCG Licensed OUPV Captain, ASA 101/103/104/105/106/114/118 Instructor - Also certified in Marine Electrical Systems
eherlihy is online now
post #22 of 22 Old 05-15-2019
Have looked your boat up in Sailboat Data? Usually the weight of the ballast is stated. They even state the ballast material but sometimes it’s left out. Good luck!
Wwp-19 is offline
Need to know! 1972 Catalina Fin Keel - Is it lead? Thanks! outdoorsman37 General Discussion (sailing related) 7 12-04-2011 09:01 PM
Fin Keel or Shoal Keel acmecoyote General Discussion (sailing related) 11 05-06-2011 05:39 PM
Is adding a fin or bulb to a fin keel ok? rangeryacht26 Sailboat Design and Construction 10 09-12-2008 10:13 PM
Shoal draft keel versus regular fin keel GBurton Boat Review and Purchase Forum 21 08-18-2007 12:33 AM
Fin/spade vs Modified fin skeg? orthomartin Boat Review and Purchase Forum 17 01-08-2007 07:44 PM
