What Happened to Boatcheck Reviews ? - SailNet Community
SailNet FAQ No Posting Please
 1Likes
  • 1 Post By olson34
post #1 of 6 Old 03-07-2020 Thread Starter
Question What Happened to Boatcheck Reviews ?
While looking thru some personal archives, I found a copy of a two page boat "owner's review" that I posted to this site in 2005. Is this section of the site still alive?
Thanks.
MarkofSeaLife likes this.
1988 Olson 34, by Ericson Yachts.
Sail # 28400
Betamarine 25 (new 2018)
RCYC, Portland, Oregon
olson34 is online now
post #2 of 6 Old 03-08-2020
Moderator
MarkofSeaLife's Avatar
Dock
Re: What Happened to Boatcheck Reviews ?
Yes please!!!!!!!!!!!
https://www.sailnet.com/forums/boat-reviews/
Mark
Sea Life
Notes on a Circumnavigation:
People can say they want freedom, but offer them the keys to what chains them, a map to where they want to go,
And they'll turn it down for the cell they know
MarkofSeaLife is offline
post #3 of 6 Old 03-08-2020 Thread Starter
Thanks for the link. Looks like entries beyond a certain date (July 2009) have been purged. Is there a rolling expiration date limit? If so , that might be a way to control digital storage cost, perhaps.
I guess I had not thought to find or click on that part of the site for a long (!) time...
Sail # 28400
post #4 of 6 Old 03-08-2020
Moderator
Dock
2009 was in the last millennium, wasn't it?
We're very modern here.
Ummmm that means, are readers really interested in a 10 year old review? I doube it. So knock up a new one, with a new inspection/views and we will be very happy to have it here
Sea Life
post #5 of 6 Old 03-08-2020
Learning the HARD way...
eherlihy's Avatar
Fortunately Archive.org forgets little.
See https://web.archive.org/web/20150910...son-34&cat=449
Review Date: Thu May 19, 2005 Would you recommend the product? Yes | Price you paid?: None indicated | Rating: 0
Pros:
Cons:
34 feet LOA, 10'10" Beam. Balanced masthead rig, VERY easy to sail. Helm is not touchy and the boat tracks well. Ours came with the wheel option, but I would consider a tiller model a bonus "find." Unlike some boats, a wheel is not needed to cover up poor handling.
Excellent husband-and-wife or single-handing boat. We live aboard for two weeks at a time during vacations; we enter one "cruising race" per year and do very well each time. Hull shape is Very similar to a Carl Schumacher-designed Express 34. Roomy tricabin layout. Both fore-peak and aft cabin can each sleep a 6'2" guy w/spouse, with room to spare. Each settee can also sleep a 6' 2" person . Large navigation table faces forward, on the port side across from the L-shape galley. There is room under the tilt-up nav. tabletop for many charts, half-folded. Aft head, to port, with counter and basin, h&c; pres. water and pull-out shower faucet. The galley and head fixtures are all high-quality "Grohe" brand.
Three large hanging lockers -- forward, aft cabin, and head compartment. Tankage: 15 diesel and about 40 water, with the optional factory second water tank aft. We have replaced the stock plastic water tank under the starboard settee with a larger custom SS one that holds 38 gallons compared to the stock 23 gallon tank.
3-Cyl Universal 23 hp diesel with open access from front, top and starboard side. Six foot draft, elliptical lead keel and elliptical rudder. Note: Ericson reportedly sold one or two with a wing keel. Deck to hull joint is inward overlap, thru-bolted with a slotted alum. toe rail -- strong and leak proof. All interior moldings are glassed to the hull. Solid hull lay-up with balsa cored deck. The interior moldings are balsa cored also, to conserve weight.
Batteries: Two standard group 24 with 1-2-all switch. There is room to easily upgrade to two golf cart batteries for a larger house bank and install a separate starting/emergency battery under the aft berth, and I did this.
Good ventilation - 5 opening ports. Mine has the optional second water tank, wheel, spinnaker, and winch upgrade package, with Lewmar 46ST primaries and 43ST secondaries. There are two 30ST Lewmar's on the housetop for halyards. Hydraulic integral backstay and gas-pressure rod vang are standard. H & C pressure water is standard, as is an Origo 6000 model gimbaled stove-and-oven. The ice box is well-insulated except for the lid, to which I added a layer of rigid foam before installing a Frigoboat(r) refrigeration system. One electric and one manual bilge pump. The head has a holding tank, also with provision for overboard discharge and pump-out where legal. The traveler and six-part mainsheet system is all Harken, and is conveniently located on the bridge-deck, which is far easier to use than the housetop versions one sees on "sailing condo" boats.
Rig is double-spreader, with in-line shrouds plus check-stays (which I only use out on the ocean). My rig is wire, but a few reportedly have rod rigging.
Cabin has teak bulkheads and large *sturdy* teak dining table with two fold-down leaves and bottle storage in the center compartment. Overhead is standard Ericson soft vinyl with zipper access to the hardware backing. Sole is teak and holly ply, and we refinished ours with varnish. large and complete AC & DC breaker panel, same as the late 80's E-34/200 . AC outlets are GFI protected.
The rudder post is oversized compared to similar boats from other mfgrs. Alloy mast step is on top of a molded-in rib and easy to keep dry and inspected. We added a PSS shaft seal so our bilge is always dry, except for some winter rain water down the inside of the spar. We have hull #8, molded out in '88. All of these were built by Ericson with solid frp hulls, except #1, constructed by Pacific Boats, which had a cored hull. After hull #1, Pacific Boats went out of business and the tooling (for this and the O-911S and the O-25) was purchased by Ericson Yachts and continued in production for two more years.
The fastest "standard" PHRF I know of is 99, in the SF Bay area. Our boat can sustain over 9 knots on a reach with our furling 135 genny -- effortlessly. These are not always easy to find, or cheap, but well worth it. We looked for a year before finding ours. We have owned ours since '94, we are still very pleased. Diagrams, a review, and a brochure copy are available for d/l at www.Ericsonyachts.org, and information may be exchanged with other owners at that site, and there is also regular discussion on the Ericson Forum at Sailnet.com.
Questions? Drop me an email.
USCG Licensed OUPV Captain, US/Sailing BKB and ASA 101/103/104/105/106/114/118 Instructor - Also ABYC certified in Marine Electrical Systems,
eherlihy is online now
post #6 of 6 Old 03-08-2020 Thread Starter
Lightbulb Re: What Happened to Boatcheck Reviews ?
Ah Yes. The 'way back machine' !
Thanks,
Loren
Sail # 28400
