wing and wing - SailNet Community
 2Likes
post #1 of 13 Old 11-04-2016 Thread Starter
davidpm's Avatar
wing and wing
Do you agree that wing and wing is by definition also sailing by the lee?
Learn to Sail Like a Pro - Master the Art of Wing-and-Wing Sailing!
davidpm is offline
post #2 of 13 Old 11-04-2016
Re: wing and wing
I used to race a 20' one design keel boat for many years in the "white sails" class. Lots of races all summer and several trips to nationals.
We sailed it DDW, but not by the lee. Matter of fact we usually tried to keep the TW a tad over the quarter on the jib side. We would let the pole ease forward a bit - sometimes quite a bit - to maintain speed when we were almost but not quite... on a reach.
So, by definition, I would say: "no'.
Loren
olson34 is online now
post #3 of 13 Old 11-04-2016
Re: wing and wing
Agreed with Loren. It can be does not have to be or shouldn't be. I almost never sail DDW, because the swell in the Pacific when offshore makes it hard to keep from sailing by the lee as the stern gets pushed around. I could run a preventer but it is too much work I'd rather just sail at a hotter angle and make up for the heading change with boat speed.
Jordan
West Wight Potter 14 "Lemon Drop"
Oceanside CA
jephotog is online now
post #4 of 13 Old 11-04-2016
Re: wing and wing
It's only by the lee for a moment, just before the mizzen gybes
MastUndSchotbruch and seabeau like this.
Capt Len is online now
post #5 of 13 Old 11-05-2016
Re: wing and wing
I would submit that it's much easier to prevent the jib/genoa from collapsing when sailing WonW if you are slightly 'by the lee', esp without any sort of whisker pole.
I wouldn't say it's part of the definition, but I would say it works...
Faster is offline
post #6 of 13 Old 11-05-2016
Fortuitous
chip's Avatar
Re: wing and wing
Yeah, the definitions are unrelated. Wing and wing is when the sails on different sides. By the lee is when the wind is coming from the same side that the main is on. You can sail wing and wing either way. Sailing slightly by the lee is often the fastest way to sail DDW with white sails, as Faster describes, but I'd keep it slightly on the jib side if there were taller waves or squirrely conditions.
In a true displacement boat, if you can get to hullspeed DDW, there is no faster way to get to a point in that direction, which is often the case when I'm doing something like a windward-leeward race. My only way to heat it up is to sail a little bit by the lee if the conditions allow for it.
My Boat Log, or "blog" if you will:
chip is online now
post #7 of 13 Old 11-07-2016
Old as Dirt!
svHyLyte's Avatar
Re: wing and wing
Sailing down wind "by the lee" simply means that the main boom is on the windward side of the yacht. If the main is prevented forward it's not particularly risky provided the leach is forward of the apparent wind. We have sailed down wind "by the lee" with and without a whisker pole although it is not something I like doing as it takes concentration and a gentle hand on the helm. Even though one sails somewhat farther, reaching off and gybing down wind can be faster, overall, and makes for less excitement.
svHyLyte is offline
post #8 of 13 Old 11-07-2016
pdqaltair's Avatar
Re: wing and wing
I find that about 2-5 degrees by the lee is most stable, with a tight preventer. Because it is a cat, no whisker pole is used (wide beam). If I used a pole it might be DDW.
Yes, even on a cruising cat it is provably the faster way DDW, unless the chute is up. Nice for sailing down a river, since minor turns require jibing only one sail at a time.
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #9 of 13 Old 11-07-2016
Barquito
Barquito's Avatar
Re: wing and wing
Faster and Chip nailed it.
Without a whisker pole, I need to sail by the lee to keep the jib from collapsing. Not needed if poled-out.
Valiant 32
Barquito is offline
post #10 of 13 Old 11-08-2016
Re: wing and wing
The boom will not be in danger of jibing until the apparent wind gets onto the opposite side of the boom. Many unintended jibes happen because the main boom has NOT been let out all the way. It's too far inboard. This is often considered safer. It is not. If you get a sudden wind shift, the wind has a much easier time getting onto the opposite side of the boom. If it does, you will jibe. Keep the boom out all the way as close to the shrouds as possible. This gives you a lot more room to play with in shifty winds.
tellemark32 is offline
Wing on wing zfactor Learning to Sail 50 06-02-2014 08:17 PM
Wing on Wing BreakAwayFL Learning to Sail 24 03-23-2012 12:28 PM
Wing on Wing, disconnecting the Whisker pole L124C Seamanship & Navigation 15 10-25-2009 02:05 AM
Wing & wing using staysail? Ilenart General Discussion (sailing related) 9 08-20-2008 01:27 PM
Wing to Wing How? 1970Columbia34 Learning to Sail 26 05-25-2007 07:38 PM
