OpenCPN - Page 2 - SailNet Community
 17Likes
post #11 of 44 Old 08-24-2018
Re: OpenCPN
Cool, I have a Spirit 23, yours is sometimes called a Spirit 21, but you should like it. Did you do the paint?
In any case, OpenCPN takes a pretty strong PC IMO, it is really unresponsive and the raster charts do not look good. For me I got a cheap windows 10 tablet and I run PolarView on it, which works great with a USB gps, but no ActiveCaptain support.
AquaMap seems like the one of the best options for IOS ActiveCaptain support.
Edit: For inland (lakes) navigation I use Navionics Marine app on my iPhone which works well.
@lho crowdsourced boat info, https://activecaptain.garmin.com
tschmidty is offline
post #12 of 44 Old 08-28-2018 Thread Starter
Re: OpenCPN
How do you like your Spirit 23?
I did do the paint, with the help of my girlfriend. Interesting choices of colors, right?
OpenCPN ended up working on my Galaxy Tab A, but I think you're right. It is a bit on the unresponsive side. It might be enough for my purposes though as I only plan on using it on the Great Lakes.
I looked up this ActiveCaptain. Very interesting! I'll have to try it on my tablet.
Josh Perry is offline
post #13 of 44 Old 08-28-2018
outbound's Avatar
Re: OpenCPN
Run navionics on an iPad Pro in a life proof case as a backup. Good screen.readable charts. Survivable in the cockpit. Have north and South America in it and get updates down loaded when I remember (monthly) which seem accurate. Costs $27.50/ year.
Have cpn in the toughbook at the nav station as another backup. PIA. Updating slow and uses too much data so more expensive over a year than Navionics. Iím stuck with the toughbook as my SSB modem is hooked up with it but if you donít need that functionality would be a big spender and do navionics.
s/v Hippocampus
Outbound 46
outbound is online now
post #14 of 44 Old 08-28-2018
Rainwatcher
Re: OpenCPN
Oh, god, no. Anything but Navionics (or Navimatics).
More than twenty years ago, a lighthouse was removed here on Puget Sound. About fifteen years ago, I complained to Navionics that it was still on my charts. So they removed the magenta exclamation mark, and left the line of text with the light characteristics.
After that, I'm not interested in any company that takes NOAA charts and edits them. I'm only interested in real charts.
MastUndSchotbruch and CVAT like this.
"When I have your wounded." -- Major Charles L. Kelly, callsign "Dustoff", refusing to acknowledge that an L.Z. was too hot, moments before being killed by a single shot, July 1st, 1964.
Black Lives Matter. All confederate symbols and monuments need to go.
Proud to live in a sanctuary city.
Jammer Six is offline
post #15 of 44 Old 08-28-2018
TakeFive's Avatar
Re: OpenCPN
Originally Posted by outbound View Post
...Have cpn in the toughbook at the nav station as another backup. PIA. Updating slow and uses too much data so more expensive over a year than Navionics. I’m stuck with the toughbook as my SSB modem is hooked up with it but if you don’t need that functionality would be a big spender and do navionics.
I'm curious what, exactly, causes OpenCPN to use so much data for you? I run it free-standing with no internet connection (except for Google Drive, where I sync up waypoints and routes that I mark when at home), so zero mobile data consumption. My charts are kept locally on an SD card, which I update on shore using the convenient ChartDownloader plugin. But I don't update everything every time. I just keep up to date on my local charts, and everything else gets an annual update (by my choice). So even on shore I don't use that much data.
Rick S., Swarthmore, PA
USCG Certified Captain, OUPV and 50 Ton Master
2001 Catalina 34MkII Tall Rig Wing Keel Breakin' Away, Universal Diesel M35B, Mantus 35 lb. anchor, sailing out of Rock Hall Landing Marina
TakeFive is offline
post #16 of 44 Old 08-28-2018
Re: OpenCPN
@Jammer -six One of the reasons I love PolarView, downloads NOAA charts and will auto update them as new versions are released. Pretty reasonable at $16 a year or so (other options but to be that seems reasonable).
post #17 of 44 Old 08-28-2018
Rainwatcher
Re: OpenCPN
My two favorites are SeaIQ (I like it for the quilting) and my old warhorse iNavX. On iNavX, you have to load each chart, but it's not that tough, and it happily takes Canadian raster charts, which is something that SeaIQ doesn't do.
Both are less that fifty bucks, and while Canadian charts cost money, the NOAA charts are free.
post #18 of 44 Old 08-28-2018
TakeFive's Avatar
Re: OpenCPN
Ditto for OpenCPN, except totally free. I've used both, and their interfaces are different, but whichever you prefer.
I share the skepticism over any electronic charts that "translate" NOAA's stuff into a proprietary format. It seems like it's just begging for errors to be made. Much better to use a program/app that takes native NOAA charts and displays them unchanged. Even better if the same program can display both RNC and ENC formats, since each has its plusses and minuses.
MastUndSchotbruch likes this.
TakeFive is offline
The Following User Says Thank You to TakeFive For This Useful Post:
elliowb (08-29-2018)
post #19 of 44 Old 08-29-2018
Re: OpenCPN
The simplest solution is one of the inexpensive nav apps available for a smartphone or tablet. OpenCpn has a following and is free, but it's not plug and play. You need to deal with a few things. The more technically oriented find that a no-brainer. Others, not so much.
I've personally used: Charts and Tides, Garmin Blue and Navionics. I never had to read a single instruction for any of them to get them up and running or to quickly figure out how to use them.
For what it's worth, C&T was the cheapest and I've liked it the best. It had Active Captain interfaced offline, which was an outstanding resource, while cruising. Lost it when Garmin took over and updated the interface. Never like the Garmin Bluewhatever app, it looked like a cartoon. I used Navionics for the first time this season. It's fucntional. The auto route feature is nice for coastal hop planning, but can't be taken literally.
Jeanneau 54DS
Minnewaska is offline
post #20 of 44 Old 08-29-2018
contrarian's Avatar
Re: OpenCPN
I use Open CPN as my primary nav tool on a LenovoT440 laptop and have used it for a 300 plus NM crossing of the Gulf as well as a guide to Tampa Bay of which I had zero local knowledge of. It's a great tool for the price (free). I use the marine navigator app on my phone as a backup but it seems to be quite battery hungry so I have to limit the usage. I was recently sailing single handed in my local bay of which I am quite familiar and trying to thread my way through an unmarked channel using only the depth sounder and a paper chart (I had left my phone on the charger in the truck). There was a storm was brewing and I was trying to get to a protected anchorage before the storm hit. Turned out to be a white knuckle event for me. Over canvassed, tacking and trying to look at depth sounder and hold on to the paper chart was nerve racking to say the least. The $10.00 phone app on the phone would have reduced a lot of stress.
lho likes this.
contrarian is offline
Using OpenCPN with GX2100/2150 DSC and AIS TakeFive Gear & Maintenance 3 01-04-2011 03:45 PM
opencpn add charts QuickMick Gear & Maintenance 1 03-01-2010 08:05 PM
OpenCPN Free Navigation Software Alalala Cruising & Liveaboard Forum 26 02-02-2010 12:16 PM
Help a noob with NMEA, OpenCPN, Garmin, Raymarine bobdamiano Electronics 9 01-03-2010 06:30 PM
OpenCPN question bhcva Electronics 7 09-12-2009 06:33 AM
