ambient wind vs true wind - Page 3 - SailNet Community
 15Likes
post #21 of 28 Old 02-27-2019
davidpm's Avatar
Re: ambient wind vs true wind
Originally Posted by JoCoSailor View Post
When sailing, you are more interested in the effect the wind has on the boat rather than measurements from a purely meteorological point of view, so True Wind is the preferred choice over Ground Wind.
I'm very familiar with NauticEd material and have to warn you that his material is based off European standards and nomenclature.
You often find some differences between his nomenclature and what may be common in the US.
He is not wrong just New Zealand
JoCoSailor likes this.
davidpm is online now
The Following User Says Thank You to davidpm For This Useful Post:
JoCoSailor (02-27-2019)
post #22 of 28 Old 02-27-2019
Yeah, you are right. Apparent wind, Gust and Ambient Wind are totally different terms.
Zahabiya01 is offline
post #23 of 28 Old 02-28-2019
Dock
Knowing all this stuff about apparent, ambient and true wind is a waste of time while sailing, because if the boat is moving, what you are experiencing is apparent wind. I never find the wind to be true, even standing on the dock, because it is never really steady. Knowing how to read gusts while sailing and determining lift is another skill that comes with practice. One needs to be particularly interested in actual wind sailing downwind (accidental gybes have taken down many a mast).
geoirishbox is offline
post #24 of 28 Old 02-28-2019
Administrator
Jeff_H's Avatar
Originally Posted by geoirishbox View Post
Knowing all this stuff about apparent, ambient and true wind is a waste of time while sailing, because if the boat is moving, what you are experiencing is apparent wind. .
I assume that this is sarcasm. But seriously, if knowing the true wind direction is a waste of time, how do you know when to tack and lay a mark or channel without having a general sense of the true wind direction.
The ambient wind vs gust discussion derived from a discussion of NOAA weather station wind readings on a particular day. Understanding predictions and recorded wind conditions in standard terminology allows you to better understand how to set up your boat based on the predicted or experienced conditions.
Jeff_H is offline
post #25 of 28 Old 03-02-2019
Dock
I am sorry I was a little cavalier when I mentioned knowing "true wind" is a waste of time. But "general direction" is about the best one can do while underway. Usually, I think determined by "pinching" while going to windward. Each tack will likely differ.
post #26 of 28 Old 03-02-2019
You guys must be very bored.....
RegisteredUser is online now
post #27 of 28 Old 03-02-2019
Crazy Woman Boat Driver
Melrna's Avatar
Send a message via AIM to Melrna Send a message via Yahoo to Melrna
True winds.. Winds are almost always given in true direction by the weather forecasters in all forecasts. This gets to be very important because most of us sail using magnetic heading vs true to sail a course. Since there are only 3 kinds of wind, on the bow, to much or too little, one can always assume while cruising the wind is forward of the beam. So depending on where you sail, a good sailor always take the magnetic variation into account before setting sail and cursing the weather gods. Down here in the Caribbean that can be as much as 18 degrees. Back in the US the average I believe is 8 degrees of north. Read the compass rose on your chart plus annual variation to get the magnetic deviation. Now since the apparent wind angle will move forward of the beam when sailing, adding the two variations will determine how much you need to beat into the wind, take a tacking duel (getting beat to death and partner not happy)or just forget about it all and turn on the motor. The later will get you there fast , anchor down quicker to watch all evenings entertainment of others getting into the anchorage or dock. Plus you will be further along with your favorite adult beverage of choice. Did I mention the Admiral will be happier!
Melissa
Currently Bequia, Grenadines, St Vincent
Melissa Renee
Moondance
Catalina 445, Hull #90
Melrna is offline
post #28 of 28 Old 03-02-2019
SanderO's Avatar
Melissa
Figuring out your point of sail is not all that difficult. You can motor directly into the eye of the wind... apparent wind direction is close enough to true wind direction (let's forget about current set for the time being). Now take a look around... at your surroundings and your boat on the plotter and the heading line ... that should pretty close to the direction of the true wind. If you destination or mark is forward of the beam and more than the lower (more) angle you can sail.... say 40į then you you can fetch the mark without tacking. Heck if you have a sailboat you can figure this out. NOAA weather is good enough to get you gears working and figuring out what you will be facing one you get off the mooring/anchor.
pay attention... someone's life depends on it
SanderO is online now
ST60 Wind Transducer does not show correct true wind TakeFive General Discussion (sailing related) 18 09-19-2016 02:00 PM
Calculating true wind MarkSF Gear & Maintenance 11 01-24-2013 10:16 AM
ST80 Shows No Difference Between True/ Apparent Wind OffshoreDreamer Gear & Maintenance 8 08-03-2012 07:58 AM
True Wind vs Crazy Speed Transducer bacampbe Electronics 16 10-15-2009 10:17 AM
True Wind Speed and Direction SEMIJim Gear & Maintenance 34 12-01-2008 05:28 AM
