SailNet Community (https://www.sailnet.com/forums/)
-   Seamanship & Navigation (https://www.sailnet.com/forums/seamanship-navigation/)
-   -   Chain Snubber "tell tale" (https://www.sailnet.com/forums/seamanship-navigation/329398-chain-snubber-tell-tale.html)
SanderO 04-26-2019 09:47 AM
Discovered a very useful technique for anchoring with all chain.
Here it is.
Get yourself a mooring compensator like this:
Rubber Mooring Snubber - Taylor Made Products 2019 Catalog
Use the appropriate size line and compesator for your boat. The line should be about min 30' long. Do an eye splice at one end. Attach your chain hook the use the small eye.
Next set up the compensator so that its 4-6 feet from the eye splice/chain hook. For safety... add a lobster float at the end so if you drop the snubber one end is float and you can retrieve it.
Drop your anchor... chain should be marked. I have marks at 50, 100 and 150 feet for 200 feet of chain. lay out the correct scope BASED on the depth... not the free board ht.
Next hook the chain hook of the snubber line to the chain at or just aft of the anchor roller.... wherever it's convenient to reach.
Lay down more chain holding on to the snubber line until the chain hook has disappeared below the water. The conpensator needs to be ABOVE the water so you can see it. Now lead the snubber line to a cleat and tie it off.
Next lay out more chain and the snubber wull be taking the anchor load.
Here's what the compensator will tell you.
Assumes decent wind force or engine in reverse... so boat is pulling after on the anchor
ANCHOR NOT SET
mooring compensator DOES NOT unwind and DOES NOT stretch... you may be dragging or the chain is in a pile at the bottom.
ANCHOR SET
Mooring compensator DOES unwind and DOES stretch. This tells you that the anchor is set and resisting (holding the boat) the force of the motor or the wind. The more it unwinds... the more it stretches... the greater the force on the anchor tackle.
The mooring compensator will tell you IF your anchor is set or if it not. PERIOD FULL STOP END OF STOREY.
NOTE: The anchor could break free in strong winds. If it does the compensator will show no stretching and no unwinding. So if it gets windy... go forward and observe the compensator as it's telling you if you are set or dragging.
This system has not failed me once in 25 years. BUT IN STRONG WINDS AND / OR CURRENTS YOU NEED TO PERIODICALLY CHECK THE COMPENSATOR.
mainemandean 04-26-2019 10:12 AM
Re: Chain Snubber "tell tale"
Great idea! A visual drag snitch.
MikeOReilly 04-26-2019 10:30 AM
Interesting approach. I can see and feel my snubbers stretch out under load, but I can see how the rubber link would be an easy visible marker.
I always set my anchor on straight chain only. I only add in the snubber at the end, after the anchor is set and well dug in. Not saying the other way isnít fine, but without the snubber on it is absolutely clear when the anchor is holding as the chain goes straight and hard.
SanderO 04-26-2019 12:03 PM
Chain can go straight when the boats dragging... the bottom offers some resistance... the compensator technique assures that the rode is secured to the bottom and taking a serious load... enough to hold the boat.
If the wind is light you STILL want to load up the tackle to set it well so that when the wind DOES pipe up the anchor system is set for the higher load. I am not sure the rating of these compensators... but I am sure that you can compute the force by how much it elongates. Kinda hard to see that in a plain bare snubber line.
capta 04-26-2019 02:15 PM
It seems that every time you anchor, this snubber is wearing on the snub line in places you can't see.
Any more elasticity in our snub line would just create more movement of the boat. I can't for the life of me see any improvement on a properly sized nylon spring line with chafe gear at the boat and a proper chain hook in the chain.
KISS has always been considered a pretty good idea around boats.
SanderO 04-26-2019 03:31 PM
Cap... this is a very simple system... no different from YOUR snubber except it includes the "tell tale" mooring compensator. There is no additional movement.. a slight twist which shortens the line a few inches. No additional chafe. In fact leading the snubber line over the bow roller reduces chafe.
I added a float which can be handy of you have to leave your anchor and dive down and retrieve it later.... it will serve as a marker buoy.
capta 04-26-2019 05:58 PM
I've seen those used on dock lines for half a century or so and didn't think them a particularly good idea for that purpose, so I can't see using one on a snub line.
I just do not see the plus.
As for anchoring, if one throws the proper amount of heavy metal in the water, a well-designed anchor like a Rocna should do its job. At least it has for us for nearly 4 years, and we only back down if Med mooring or in a flat calm, so we can lay the chain for the expected wind.
MastUndSchotbruch 04-26-2019 06:46 PM
Originally Posted by capta (Post 2051598508)
I've seen those used on dock lines for half a century or so and didn't think them a particularly good idea for that purpose, ...
Why not? Don't you think that another inch or two of elasticity in the dock lines is a good thing, to lower the load on that hardware (cleats and stuff)?
MikeOReilly 04-26-2019 06:49 PM
Like I said, I think itís interesting, but I have to side with Capta on this ó I donít really see the utility. I donít have any problem seeing and feeling my snubbers load up under strain.
Actually, the one benefit I could see is that it might add more elasticity to a short snubber. Perhaps in tight quarters this would be a good idea.
RegisteredUser 04-26-2019 06:55 PM
Those things have been around eons.
On another topic...
I dont want to run snubber over bow roller...chafe can be easily dealt with.
Use the right size rope and you get enough elastisty...no snatching.
I think a lot of people oversize
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
