Charter with disastrous Outcome - Page 2 - SailNet Community
 6Likes
post #11 of 24 Old 10-11-2016
Re: Charter with disastrous Outcome
Originally Posted by SanderO View Post
Can you charter a boat... cross the Atlantic to participate in a race, and then sail it back to UK?
I don't think that is the setup exactly. They run racing seminars or corporate racing retreats either in the Med or the Caribbean, depending on the season. The boat only goes makes the crossing twice a year depending on the season. The paying passengers on the trip home were probably different people from those that raced the boat in the Carib.
As Capta said if you got the money everything is for sale or every option is available.
Jordan
West Wight Potter 14 "Lemon Drop"
Oceanside CA
jephotog is offline
post #12 of 24 Old 10-11-2016 Thread Starter
SanderO's Avatar
I looked at one the pics of the keel bolt attachment... I saw 8 bolts... My boat has 16.. twice as many. I don't know the weight of the Bene keel but mine is about 6000# more or less so so that's under 400# . bolt.... the Bene ballast is similar so it's bolts were carrying 800# or more.
Contest 36s keel has a 16" x 10' flange integral with the keel which I am sure is very different from the Bene...
The keel bolts came loose or sheared I suspect
That seems weird.
SanderO is online now
post #13 of 24 Old 10-12-2016
Bristol 45.5 - AiniA
Originally Posted by miatapaul View Post
Not sure of any currently doing it, but there have been some races specifically designed for this. I think the Sir Robin Knox-Johnston's Clipper race was set up like that, they built all boats to be the same, and you chartered the boats from them to participate.
But this situation will certainly make any charter companies think twice. I have also heard that people will charter boats to race locally especially in the Caribbean.
Clipper race is still going strong. You don't charter a boat for this. You buy a berth for one or more legs of the race. The captain is a professional hired by the race organizers and I think there might be a couple of additional pros on board.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
post #14 of 24 Old 10-13-2016
TQA
Bombay Explorer 44
TQA's Avatar
I think the title to this might be misleading.
AFAIK this was really a delivery with the skipper being paid to make the trip to move the boat to where it could start earning again.
Is this a gray area if a crew member pays to make the trip?
Would it be beneficial to operating company to call it a charter for insurance purposes?
TQA is offline
post #15 of 24 Old 10-13-2016
That seems weird.
If you read the report and look at the photos, you will see that the bolts pulled through the hull rather than breaking. That seems worse than weird to me.
Loki9 is offline
post #16 of 24 Old 10-13-2016 Thread Starter
SanderO's Avatar
Maybe yes and maybe no... If the keel bolts sheared and the boat went turtle and the bolts were not glass in then the could have just dropped out and fallen to the bottom of the ocean. To pull thru the heads would have to shear off. Possible but unlikely... and the shafts with the keel drop.
post #17 of 24 Old 10-14-2016
outbound's Avatar
Think this speaks to a more fundamental issue. The culpability of production builders marketing their boats as blue water vessels. Some have said they are fully capable but have a definite service life in that use. Others have said there as been an evolution of what's available in the current production marketplace that makes these boats less then ideal.
Looking at design features. Their are innumerable boats with external ballast where the the keel fits into a stump and is attached by a host of bolts. The keel itself is soft lead not iron. Design allows forces to spread and be well below that of failure point of canoe body or attachments. There are boats in production with this type of external ballast examples being pacific seacraft, rustler, HR passport etc.
However the big three do not make use of this design.
The other alternative of internal ballast has no issues with keel bolts but is at potential risk of damage to hull aft of collision bulkhead in a hard grounding such as hitting a rock ledge at hull speed but by design less likely to injury in typical groundings. Examples are the various aluminum keel/centerboards such as Boreal, Atlantic and a few solid glass boats such as Outbound.
There are extremely strong boats making use of the keel attaching directly to canoe body without a stump but this requires design engineering beyond a level the average boat buyer can appreciate. So we are dependent on the various rating bodies. This gets back to what the EU rating actually mean.
I'm not in a position to judge culpability in this specific case. I do not have sufficient knowledge of naval architecture, maritime law nor the rating rules. I think this case should inform our decisions about what we take offshore.
s/v Hippocampus
Outbound 46
outbound is online now
post #18 of 24 Old 10-14-2016
Administrator
Jeff_H's Avatar
This is a very complex case. Cheeki Rafiki was a stock Beneteau 40.7. (These are boats that I know well have raced one for quite a few years) These boats were conceived as full fledged racer-cruisers. Sistership 40.7's have won just about every major race in the world beating grand prix level boats in a very broad range oc conditions. And although they were clearly production boats, they were not the usual production boat in terms of production methods or quality controls. The appendix in the detailed Inquiry Report describes the engineering process that Farr Yacht Design employed, which not only specified the structure but also the quality control and testing that was required. It also detailed the testing that Beneteau performed as well.
The report concluded that the design met or actually exceeded the structural standards of the day, and that the level of testing was extraordinary. When you read the testing and documentation process on these boats it become pretty obvious that few if any custom, or semi-custom boats, let alone production boats receive this level of care, testing and documentation of results. In other words the report appeared to conclude that there was nothing inherently wrong with the design or construction for its intended purpose.
But, it needs to be understood that like any relatively lightly built race boat, the safely margins are smaller on a purpose built race boat, and so greater care must be extended to inspect for damage whenever a impact occurs and repair any discovered damage. No boat is indestructible, but a grand prix level competitive race boat tends to be more vulnerable. This boat had a tough life for any boat.
To preface my next comments, in my opinion, like most production boats, boats like these were engineered for a specific purpose. That purpose included coastal cruising, fleet racing including offshore courses, and occasional passages offshore. A really heavily used boat with that design brief might sail 1,000 miles, maybe 2,000 at the most. A heavily campaigned race boat might sail a dozen major races in a season and dozen or more minor ones as well. And most race boats (but obviously not all) are retired from heavy campaigning after 10 years or so.
And it needs to be understood in the context that racing can put huge loads on a boat. They are sailed in all conditions with crew weight on the rail resulting in several times the stability more than what comes from their keels. They tend to be raced with the absolute upper limits of the amount of sail area that they can withstand and remain marginally controllable. In heavy going, they are steered as much with the mainsail as the helm. This places enormous loads on sails, rigs, and rig attachment points. And to a lesser extent, those loads end up as very high side loads on their keels, and keel structures as well. .
In the case of Cheeki Raffiki, this was a boat which had roughly 20,000 miles in Ocean crossings alone. It had been through major storms while racing and while being delivered. It had a number of groundings, and range of repairs and inspections. It had over 15 years of the hardest kinds of racing. The ocean miles alone represent 10 to 20 years of what would be considered as normal use. This boat had a hard life.
The report indicated that the probable failure mode was a delamination of the bottom of the boat in the keel area and possible/probably separation of the internal framing system. The keel bolts, backing plates etc, were not thought to have been the failure mode. This is very similar to the failure mode from the Cape Fear 38 that sank in the Gulf of Mexico.
In talking with one of the investigators for the Cape Fear 38 sinking, they concluded that the failure was damage to the primary structure that then transferred keel loads to the hull. The hull was never designed to support those kinds of loads. The hull then delaminated from a mix of fatique and impact fractures until it could no longer support the weight of the keel. In the Cape Fear a piece of the bottom was ripped out when the hull failed. In the case of Cheeki Rafiki it appears that the backing plates pulled through the inner hull and pulled off the outer skin.
I personally do not have adequate information to assign blame at this point, but I do think its telling that neither Beneteau or Farr are being dragged into this. It will be interesting to see how this plays out.
MarkofSeaLife likes this.
Jeff_H is online now
The Following User Says Thank You to Jeff_H For This Useful Post:
jephotog (10-14-2016)
post #19 of 24 Old 10-14-2016
Originally Posted by Arcb View Post
Airplanes on ferry flights carrying only dead heading crew can't ignore the control tower.
This is correct in that all pilots have to obey the FAA regulations and follow the direction of Air Traffic Control. A commercial aircraft not carrying passengers for hire operate on an a vastly different set of rules than when carrying passengers for hire.
I read that the company was switching around from one set of rules to an other to take advantage of loopholes. It probably never would have been a problem if the keel did not fall off.
Jordan
Oceanside CA
jephotog is offline
post #20 of 24 Old 10-14-2016
Jeff,
Thank you for your detailed observation. I have never been aboard a B40.7 but race on B42.7 and 36.7s. Ever since the story of Cheeki Rafiki's loss I have been suspect of the Beneteau's overall construction or at least their suitability to ocean crossings. Your post gives me insight into the demands and stress caused by racing a sailboat. I knew the demands on the rig were tough but did not think about the keel. Off to read the report on the Cape Fear 38.
baywater likes this.
Jordan
Oceanside CA
jephotog is offline
Homemade exhaust riser outcome.... Dave Montgomery Diesel 8 08-13-2014 09:19 AM
Bareboat Charter Pricing and your charter experiences NVCATS Chartering 8 12-11-2012 05:35 PM
BVi Charter --Horizon Yacht Charter Company Yamsailor Chartering 18 04-06-2010 08:47 PM
Your Flotilla Charter Experience & Recommended Flotilla Charter Companies? BeautifulDay Chartering 11 11-05-2009 11:00 PM
Disastrous First Day For Sailing Gold Medal Hope Kevin Lim (Bernama) NewsReader News Feeds 0 12-06-2006 09:15 AM
HTML code is Off
