1 - 16 of 16 Posts
Discussion Starter #1
Both in great condition (the 473 is slightly better equipped) both around 200K ish. We will be sailing costal around the NE for the next 4 years then retire and head for the Carribean. Which would be the better choice?
Dlong,
That's like asking a 2001 Ford Taurus or a 1984 Range Rover...
The Benetau is newer, and you get a bigger boat, more plastic, faster sail, more space and less expenditure to keep up. The Norseman, is a very well built boat, slower, smaller and better finished...
If you're going to sail coastal then lie around in the caribbean, I'd go for the Benetau, and get more space.
Based on the minimum info you've provided, and even though I don't particularly care for the in-mast mainsail furler, I'd also suggest the Beneteau. Expect more depreciation, though.
Just to be contrary - Norseman.
If you are going to live aboard it's a 'cruiser', Bene's a racer/cruiser (mind trhat draft too, the Norseman I googled was a shoal draft which is handy in the Carib. 44 Norseman has plenty of room for a cruising couple, the extra is just that, extra Besides, on the Norseman the depreciation and upgrading is done.
Broad Reachin'
How many people will be living/cruising aboard? The Bene has more room and will probably fit your needs better if you have more than 1 person other than yourself. If you have kids, I'd recommend the Bene because of the 3 staterooms.
I personally would go with the Norseman simply because I like the more classic looks and the build quality.
dlongendyke,
Ignore Chuckles...the man sails a Cat...A CAT!!!!!!!!!! what the hell does he know about sailboats????:D :D :D :D :D :D
Next thing SD will come here and say something too:D :D
I sail a CAT because I like sailing WITH my wife :) - and for 150k its a lot of well tested boat, in fact ditch the No-man and the Bendytoy and go buy a brand new Gemini instead. Drink Rum on the hook without cupholders, hell sail without cupholders :)
At least it isn't a Catalina... ;)
dlongendyke,
Discussion Starter #14
Thanks guys! Clearly there is no right or wrong answer here. I'm leaning toward the Norseman just becuase it matches my style (slow, old and expensive!)
Thanks again!
Dave
A brutally honest answer... :) Good luck with the seatrial and survey...
Thanks again!
Dave
bene 473 is a great boat for carib. The boat sails best over 15 kts, is a pig below 10, but then again, below 10 put on the iron genoa anyway. Has a great interior, if you have the 2 cabin version, great layout. Have sailed many hours in it, if around 200 a good deal.
1 - 16 of 16 Posts
