Gary: thanks for or this
"That was 12 years ago when I was still somewhat young at age 72. Sure miss those days!" I retired in January, turn 70 in August, feeling like I might be past the moment . This gives me hope!
that will likely happen at some point, My A/C intake in the V berth and I figure i could run juice from the shower sump pump, which is on its own breaker. so I have water and volts close enough, and there is enough space around the windlass to coil up a short section of garden hose.muddy front deck and install a wash down system, you won't have to worry about that dirty, stinky mud then...
I like this. This is a great idea until I can get moving on a wash down system up there....
The technique I've adopted to both ease getting the anchor off/out of the bottom and getting the chain cleaner is this. When we have finished morning chores and could get underway at any time, but usually 30-45 minutes before we'd typically go, I'll pull us up to directly on top of the anchor washing chain as it comes on board. Then with the anchor still set, I'll snub off with the remaining chain off the bottom. The motion of the boat will then both help wash the chain and help break the anchor out. Meanwhile, I semi-relax and keep an eye out for dragging. So far, we have never had to leave before we decided to go and getting the anchor on board without a load of mud is usually much easier.
The frame is easy (pre fabricated bimini frame off e bay). It is the canvas work that is the challenge.Boat projects this year are killing my sail time... And wallet
Think twice before you choose to make your own dodger... Just say'in haha
Don't know if you are missing anything, you probably know this already: Don't forgot to drill the holes for the screws slightly large, to allow for the different expansion coefficients of metal and plastic and avoid cracksI found a shop near Baltimore that had a piece just the right size and thickness for both hatches... It's not as dark as the original but I cam live with that. They will machine it as well, so all I need to do is re-bed the acrylic and then the hatch to the boat. I think I'm going to use Butyl tape to bed it to the deck and Dow Corning 795 to bed the acrylic. The original was just screwed in, I will probably through bolt it this time. Drill the holes and add the thickened epoxy then drill the final hole. Am I missing anything?
This is pretty much exactly what I do. I let the chain hang under the water surface but above the bottom and pull it up clean as a whistle. We usually eat breakfast with the anchor alarm set. We've never had our breakfast interrupted yet.The technique I've adopted to both ease getting the anchor off/out of the bottom and getting the chain cleaner is this. When we have finished morning chores and could get underway at any time, but usually 30-45 minutes before we'd typically go, I'll pull us up to directly on top of the anchor washing chain as it comes on board. Then with the anchor still set, I'll snub off with the remaining chain off the bottom. The motion of the boat will then both help wash the chain and help break the anchor out. Meanwhile, I semi-relax and keep an eye out for dragging. So far, we have never had to leave before we decided to go and getting the anchor on board without a load of mud is usually much easier.
