So I've taken this engine down to the chlhead and back fixing various things.
What I've fixed:
-Didn't pump water well
-Stuck carb (stuck open, drained a couple has tanks)
-Totally 100% cleaned the carb (which had recently been replaced, per paperwork I got with the engine)
-replaced head gasket while investigating the cooling issue.
Following that it seemed to run pretty well. Though on the air floor 8'6" it didn't rev up past ~2/3 throttle and perhaps decreased somewhat beyond that (it did this before my repairs too). I tentatively attributed that to drag and the inability to get on plane.
However, on a long trip, after 2 hours of running fine at half throttle it stalled out. Eventually I realized that it ran fine at idle speed and just above, but stalled beyond that. But only in gear. In neutral it revs fine though perhaps rough sounding?
Finally after this I checked the carb completely again, replaced the spark plug and changed the crankcase fluid. The prop seems to spin fine in neutral and in gear it turns over the engine as I would expect. The next day I put it on the boat and it was exactly the same. Barely runs above idle, but only has a problem in gear.
So I'm at a loss. I've done my very best to rule out the carb, it has new gas with 50:1 oil, it starts and idles easily but just dies very quickly in gear with throttle.
EDIT: Whoops, this is a Mercury 3.3 2-stroke 2003 (Same as the Nissan/Tohatsu/Mariner)
What I've fixed:
