1 - 20 of 32 Posts
So I have owned many outboards but never a 3 hp and usually over at least a 20hp with a separate tank. Can anybody give me a rough ball park figure on how far a Yamaha 3hp outboard can go on a tank of gas? I ask for the slip I reserved for my boat has a canal about a mile and a half to go down to get to sailable waters. I will of course carry an extra 2-3 gallons on board but still curious.
Depends upon fuel tank size, how much throttle you give the boat etc. I would imagine you can get and hour or two on a typical built in tank if you are not at full throttle.
Not sure if this model has the option. but some motors with built in tanks can also draw from an auxiliary tank as well.
Marty
I looked up the size of the tank at 1.4L. I would say you would push an hour of operation with a tank that size. How far you'll go will depend on how fast it will push you. I would bet you'll get the 3 mile round trip done, but not much more. Top off every time, prior to casting off.
· Old enough to know better
It is best to let the motor cool off as well before refilling. If you dribble a bit down the side you don't want flames chasing your hand with a jug of gas in it. So a smaller container is better, and less likely to spill. Also look for an older gas can that does not have the "anti spill" spout. They are kind of a good idea but most are more likely to spill rather than less. I have one that actually works well. It was cheap and at a discount store, so it has no brand name on it. (got it at Odd Lots)
· SailNet Captain of the Month
I have a 3.5 hp Tohatsu with a 1 litre tank. I've never systemically charted it, but I think I get about 1 to 2 hrs of use before having to re-fill. Of course, it depends on what you're pushing, in what conditions, and how fast you're going.
I carry a gallon (~2 litre) tank with me at all times, and can refill in pretty quickly. No cool down period needed (so far :eek:). I certainly wouldn't want to try and refill using a 4-gallon jug. Way too heavy and awkward in a bouncing dingy.
....Also look for an older gas can that does not have the "anti spill" spout. They are kind of a good idea but most are more likely to spill rather than less.....
I've never spilled so much fuel in my entire lifetime combined, as I have with these stupid anti-spill jugs in the last few years. Insane.
I would have to agree with this comment. That is filling lawnmowers, weed eaters, blowers etc on a daily basis due to the work I do! I have found one of the anti-fill spouts that is not too bad.....but still, spill more than I did with out.
marty
· Freedom isn't free
I had a 2.2hp and a 3.5 hp for my Capri 25, the essential figure is that the boat was about 2000lbs heavier than your P165. I've taken the 3.5hp off and used it on a 9foot bass tender (rowboat)... it runs the same amount of time regardless it would appear. I got about 45 minutes continuous run at Wide Open Throttle (yes same for the 2.2 as the 3.5)... what I found was they were the same motor, with some kind of restrictor on it.
I was able to get about 1.5 hours out of the 3.5 at about half throttle.
You'll find that the 3.5 will easily get your p165 to full hull speed... it got my 25 footer to full hull speed with no head wind, and could get me to 4.5 knots WOT, with a 25 knot headwind (don't ask)...
I carried a 2.5 gallon jug with me (which is easy to sling around), and never had more than 2 gallons in it (less likely to spill). If you can get one of the old cans with a regular neck and a relief valve, they are superior to the Congress mandated "no spill" types. Hanging over the stern in a pounding sea is not fun either. Add to that darkness and confused seas and you have a recipe of disaster if you aren't careful (again don't ask).
Good news is those tiny outboards are work horses. Keep the plug clean, and use high test fuel, and you should have an easy to maintain reliable OB.
Discussion Starter · #14 · (Edited)
Agree with all about the rediculous new gas cans. I hate them and pull the anti-spill guts out of the nozzle right away upon buying one.
I just didn't want to run out of gas and have over a mile to go back to the marina down the canal. I would feel really bad in asking my wife to get out and swim while she was dragging the sailboat with her. :)
Now I have to find the mixture for this thing online somewhere. I venture to say it's 32:1. Hmmm, maybe I am off and it's 100:1--that's insane.
Discussion Starter · #17 ·
There's a kit to convert to a external plug-in tank.
SERIOUSLY? I would do that in a minute. 6 gallon metal tank in the open lazarette would be nice. Have any idea where these kits can be purchased? I can search but thought I would ask.
I got mine from yamaha thru an outboard shop, in about 2000, they installed it. got tired of hanging over the side and spilling gas. I'll hunt around for some info. Might try to google it
Corsair 24
I get much more than 2 hours out of my nissan/tohatsu 3.5 at half throttle, however my boat is light...
these are all similar engines...I had an evinrude 3.3 with the exact same tank, head etc...and same carb...
I dont mind the built in tank...its one less thing to deal with out there...just carry a galon jerry can and youre good for the day...
a 3 mile combined trip is just fine on the stock tank with fuel to spare...
cheers
ps, only mix what you need for the day...
Reactions: MikeOReilly
· Junior Member
I get about a half hour with throttle at half on my yamaha 3 HP. Hardbottom 2.6 RIB
1 - 20 of 32 Posts
