Well, before I upgrade this fall to a chiller, I need to fix my current AC.
It is 16K I believe, and does not run.
I have checked the wires on the switches, all good.
I put a screwdriver on the top of the overtemp switch, bridged the connections, no luck.
The only bad looking item I found was the wire coming from the start cap to the motor. It was melted. This could have been because of the shoddy wiring at this marina that nearly burnt my boat down. So I was thinking I should perhaps replace the start cap?
