1 - 6 of 6 Posts
Discussion Starter #1
I recently bought a slightly used (told there were about 10 hours on it) tohatsu 4-stroke 6hp outboard motor to use with a mercury inflatable dinghy. I took it out for the first time this weekend and it ran great on its first trip.
When I took it out again the next day, it seemed to be working well again, but after about 30 minutes of use it seemed to suddenly make a more high-pitched noise and became what I describe as "jerky" or "jumpy." It almost seemed as if it might stall, but when i turned down the throttle a bit it still seemed run somewhat smoothly (still sounded a bit louder and high-pitched).
I was wondering if anyone might have an idea as to what caused this - I have a few thoughts/things to add:
-I believe the motor is due for an oil change. The person I bought it from said it could use one in the near future.
-I used the gas that was sitting in the fuel tank when I bought it. I'm not sure how old it was and in retrospect this was probably a bad idea. Could this be the issue?
Sailor
Bad gas is responsible for most operating problems. Try putting carberator cleaner in the tank and running it through. But first; does your motor have a window so you can see the oil level in the engine? I believe it should. Is the level at 1/2 way up that window? Do you have enough oil? If so, it's undoubtably bad fuel.
Keep a stabilizer in your fuel so you avoid this problem in the future.
Tod
Bad gas, bad oil, I'm guessing this motor sat for a while. You should really do a thorough tune up. Engine oil and filter, lower gear case oil, fuel filter, air filter (probably just a washable element, spark plug, zincs (if more than half worn). You can try to run carb cleaner through the carburetor directly, such as Valvtec Marine Motor De-Carb. I'm not sure that adding to the fuel will do much, if she is already showing signs of trouble. You may need to re-build the carb altogether. You bought a low time engine, but sitting idle is worse than being used and having more hours.
By the way, were you getting a good tail of water flowing out from the cooling?
Captain Obvious
The stalling is usually not serious... the high pitched sound? Worries me....I can only guess...... is the oil full? Perhaps a vacuum line popped off? There is one from the crank vent to the carb....
Check the gear shifter linkages. The high pitch sound, may be the motor slipping in and out of neutral.
The jumpy/jerky feel may be the motor shifting in and out of gear.
1 - 6 of 6 Posts
