I recently 3D printed some plastic fittings of PETG which I adhered to my carbon mast using 4200. The purpose was to use some self tapping screws to mount an instrument bracket. After a few weeks, the 4200 these fittings came loose, and it's clear the 4200 just let go of the carbon mast.
Is it that 4200 won't adhere to carbon or did I not prepare the surface correctly? I cleaned it with soap and water and made sure it was dry. If 4200 won't work, what can I use? I was hoping for something not permanent but if necessary I can go that route.
I realize the best way to handle this is with a backing plate inside the mast, but I don't want to pull the mast right now.
Thanks...
Thanks...
