- Reaction score
- 273
i have a mystery that i need to solve. i was checking the charge on the battery in my 1971 cal 27. the battery is under a bench, that doubles as a companionway step, at the rear of the cabin. the inboard motor used to live under that bench as well. the prop shaft is still in place. very rusted, really. i am pretty sure it hasn't been there for a long time. the previous owner used an outboard.
while checking the battery, i noticed moisture on the floor around the general area of the prop shaft. it was at night and the cabin lights don't light that area up very well. i didn't have a flashlight. it wasn't a ton of moisture but it worried me. i was concerned the log was leaking.
this spring, i will be hauling the boat. one of the things i will be doing is to plug all the through hulls, including the log. i will be glad when that is done.
anyway. i returned to day with this fiber tape i got at home depot. it's called flex fiber or fix fiber....something like that. in essence, you soak it for a few seconds, wring out the excess water, wrap it tightly around a leaky pipe or broken shovel handle and, in 5 or 10 minutes, it sets up like steel. and it does. i completely wrapped the log, where the rubber seal and hose clamps are.
i dried the water, which was a tiny bit more than two nights ago, and i waited. i saw nothing. no more water. the 'repair' was completely dry.
it was very windy today. high gusts, etc. the wind was coming from behind my boat as were the waves.
i kicked back and read for a bit. an hour later, i checked it again. there was water again. in fact, a bit more than before. i dried it up and checked the 'repair'. dry as a bone. i noticed that the floor was wet behind the log, which is uphill. since water doesn't run up hill, i figured it was coming from a point farther aft than the log.
so, i waited and i watched.
sure enough, after about 10 minutes, moisture had begun to creep down towards the log, from the rear of the boat.
there is a bulkhead that separates the engine compartment from the rear of the boat. it has a hole to allow water to move forward to the bilge.
so, i go out and look in the starage compartmet in the starboard bench. it has no bottom but opens up to reveal everything below he cockpit.
there was about a cup, maybe two, of water right up against the bulkhead. that is where the water was coming from.
i looked at the tube the rudder shaft passes through. no cracks or evidence of water from there. in fact, i couldn't see anywhere the water might have come from.
the exhaust from the old inboard is still there, unplugged. i checked but the waves weren't slapping anywhere close to that high. i had thought that, maybe, the high wind might have blown water in through that. but there was no evidence of that.
there is a steel backing plate for the prop support. it is right near the bulkhead; right were the water is.
at one point, i had hoped it was just condensation from the cold, as that part of the boat is not heated, and that it had thawed, in the warmer temps we have been having, and puddled up at the lowest point; draining down towards the bilge as the boat rocks in the chop.
but it seems too much water for that.
i am worried that that steel plate, and it's bolts, might be leaking.
but, i just don't know.
it's not a lot of water. very little, actually.. but, any water is something to worry about.
any thoughts?
any thoughts?
