1 - 20 of 20 Posts
Glad I found Sailnet
Isn't there anything that could be done?
Isn't there anything that can be done to rescue that sailboat?
It looks like there were weeks of good weather with smallinsh waves. Why couldn't she be refloated? It seems unreal that something of such value could go to waste.
I'm thinking a couple HUGE anchors place 45 degrees apart, out in deeper water, with 15 to 1 scope. Add a very powerful windlass. Add water pumps like they drive piles with, to loosen the sand in front and around the keel. Then the anchors could be used to wiggle the sailboat back out to sea again. I figure a few guys could do it in a day that way.
Why the waste??????
And I'll ask what is probably the most stooopid question of all - but, of course, I'm cool with that.
I've seen like photos of half-submerged boats to just rigging sticking up out of the sand. So my question is - can the sand really swallow a boat over time? Or does the sea just break it up at some point?
I'm also interested by Bene's question above. Sounds like insurance (or lack thereof) always has a lot to do with it. In any case I've always wondered about inflatable "jacks" (i.e. - a crazy strong "raft") that could lift the boat a few feet to clear the keel, float it with the tide, be towed out, then deflated for the re-float. I know they use something like this in emergency situations to lift heavy crap. Would it work here?
I think I have seen several sunken ships that are partially buried in the mud and muck, depending on where they went down, but these are archaeological sites, rather than a more modern vessel being sunk recently.
I've never scuba dived, but I do dive with mask and fins and could see you'd probably need some good divers to get floats of any sort in place, but why not? If you can get enough flotation around the boat to bring it up I can't see why your idea wouldn't work.
On the other hand..... not being a scuba diver I can postulate anything and make it sound easy :)
(I do have about a dozen diving friends though, and they tell me that a lot of things are a lot easier than *I* personally would try.....)
I picture all hand held equipment water pumping equipment, a couple very large anchors and the help of a big boat to set the anchors. Also, a ton of sandbags to make a jetty immediately up-current of the sailboat. Then it's move sand and wiggle, move sand and wiggle. You create the jetty with the sand you remove from around the hull and keel. The jetty keeps the sand from coming back in. And yes, it would be a race against the next storm.
I see a situation like this one as a sand problem. The waves are small for weeks after the incident. The boat would float if it weren't for all the sand (big assumption maybe).
There was a beautiful, like-new, 40+ foot Beneteau for sale on eBay a year ago that had a big hole in the side (and broken rudder) from where the bulldozer pushed it back out to sea. That seems like way to much brute force, if you ask me. I'd use the bulldozer to move sand near the boat, or as the first "rock" in the jetty, and do the rest with hand tools.
I'd like try to free a boat like that, should the opportunity appear, and should the boat be worth the trouble. There's something good or decent or __________ about it. What's the word I'm looking for?
i had to beach my boat when i lost my genny in 40 knot winds ( my furler foil broke ) at low tide i had 1 foot of water on the shore side, and i mean 1 foot till the beach not one foot deep. i was able to get my self off, using my anchor and my sails along with high tide. first i got the boat to lean out by sail and anchor off a halyard, then used the waves to bounce the boat 45 degrees to the beach with the anchor off the stern to a winch and lots of tension. then when tide came in ( i was still at 15 degrees of heel ) i kept lots of tension to the anchor and ran the engine in reverse blowing lots of water under the keel loosening it more till it came free. it took me 4 hours to get off but i did it.
one word of warning—if you're running your engine when the boat in grounded, you run the very serious risk of running sand and other sediment through your cooling system and that can tear up the impeller pretty badly, so you'll probably want to inspect the impeller at your earliest convenience.
I don't know about beached boats, but using floatation bags is a common practice in my area to raise sunken boats in open water.
Add to that potentially putting more sand around your keel.
That said, I wasn't there.
Next time anyone knows of a good boat stranded on the east coast, let me know via PM or via email to Bene505 *at* hallmont dottt com.
Volunteers -- anyone want to take a crack at freeing a beached sailboat? We ought to get a rescue team lined up, people who could take a day off work and drive a few hundred miles on a moments notice. We could share the effort and investment, and we could share the reward. And since this is the U.S. of Litigation, no suing each other, or don't bother to sign-up.
Let me know if you are interested, via PM.
We could get the sandbags ready and make a list of rental locations for gas-powered pumps. Maybe we could save a good boat or two.
1977 Morgan OI 30
How did this begin? It seems like so much time went by before it was destroyed. I can understand a boat being thrown against a shoal or ledge during a storm but this was painfully slow. Was the port side stove in, was the ocean too rough for a tow...
Ship Wreck
What differates us all from them is the willingness to try to free the beached boat. My belief she was damaged severely before she came ashore. Note broken main mast. Some of us who cherish and love our boats will go to the end of the world to prevent, free her unfortuneately these people did not. Yes a Shame. But very true the shore and water is peppered with wrecks.
On the hard
Smack, ya ever stand barefoot in the surf? Ya notice how the wave action moves sand from under your foot and buries it? Same thing with boats. There's one on Sable Is. that was buried like that. A couple off the Baja coast as well.
Wow. I understand the foot thing - I just had no idea an entire boat could go down. That's really amazing.
So what do you think about the "raft jack" idea. Would it work?
midlife crisis member
Discussion Starter · #16 ·
Smack,
I do believe that this boat was torn apart by a storm and the debris floated away. I don't think it was buried whole in the sand.
I agree. I bet you built sandcastles as a kid too. Just think of how rewarding freeing a stuck sailboat would be. There's something special about it.
Smack,
Yes, it would take a lot for the whole thing to go under the sand. It probably has some flotation with respect to the sand. (It may not be as dense overall as sand is.)
I just don't comprehend. For a few thousand dollars I believe thsi boat could have been salvaged. (damage unkown). some cheap rails could have been made out of 2x12's and a crane could have picked her up and placed her anywhere. Either insurance covered the loss, or they are stupid, or they are stupid. Oh, or they are stupid.
I have experienced the dangers of a lee shore, this is horrible.
cb
Of course, a good anchor might have prevented them from ending up on the beach in the first place.
1 - 20 of 20 Posts
