I've been thinking for a long time about adding an auxiliary electric motor, and with my new boat, I might just do it.
The PRIMARY purpose would be to silently add a couple of HP while under sail to make motor-sailing a pleasant and efficient process.
Secondary functions would include using the high torque of the electric motor in close quarters maneuvering and possibly as a get-you-home backup.
With my new boat (Nauticat 40) I have copious battery capacity, and space for more, and I have a 6kw diesel genset. 6kw happens to be about 8HP, which if you follow the formula of 0.5hp/tonne to get to 80% of hull speed, means that in theory an electric motor coupled to my 6kw genset could push me at 80% of hull speed. But that's not the primary purpose. Really what I want is to silently add a few HP under sail, and as far as getting me home, I could sail (or electric/motorsail) to the marina and use the electric motor in close for docking.
Here's what I'm imagining for how to connect it. I could use a high grip shaft collar, coupled to a sprocket and motorcycle chain. The use of roller chain (motorcycle chain) would eliminate the side loads that trash out bearings.
McMaster-Carr
The sprocket could be attached to the coupler with very little imagination I would think.
What I would need is some kind of clutch (electromagnetic?) so I could engage or disengage the setup when running the main engine. I also haven't figured out the best motor to use, though there are coutless options out there.
Does anyone have an idea what kind of clutch I could use to attach this sprocket setup to an electric motor? Any ideas on hooking it up to some kind of throttle (resistor?) Any other comments or criticisms?
MedSailor
McMaster-Carr
MedSailor
