1 - 12 of 12 Posts
jimbo
I was wondering is it possible to hang a airmar transducer off a pole of the back of the boat even though it is a thru hull. I'm going on a voyage for two weeks and I need a quick fix.
I don't think the electronics head on the through-hull versions is meant to be immersed.
Well I looked at the Airmar documentation and really am none the wiser as to whether they can be immersed or not!
Remember you're a womble
Can you fit it in-hull? A combination of toilet sealing wax and some duct tape will probably hold it for long enough.
If your hull is solid glass you can silicone in hull.
Have mine in place for years. Just make sure it is reading
and has no air/voids and stays in place until cured.
No
ours was acting up so I tried a fishfinder transducer on a pole overboard. Did not work. You need to get it deep enough to be out of the turbulence from the boat and off the back it will ne significant. Maybe off the bow but I still suspect it will need to be deep, especially if you are in any choppy water. By the time you go thru all the rigging work you could ha e mounted a thru hull transducer for much less money and hassle
jimbo
Discussion Starter · #7 ·
seems like my hull is to thick. My electronics guy says it won't work. Hull to thick I guess. It's a 45 ft coronado.
I put an emergency Humming bird type, @$$70-90 on 2x2 wood pole clamped to stern rail. This transducer has wire that is screwed to the wood with the transducer screwed to the bottom of wood & pointing in the correct direction. Has to be in the water a few inches. You can raise or lower as needed. WORKED FINE on sailboat ! You are not going 20.knts
......Main problem is transducer is 45ft back from the front . Mine was 30ft . But, using Chartplotter depts. & going slow in shallow areas was good.
jimbo
Discussion Starter · #10 ·
I'm gonna give it a try. I'll keep you informed
You can hang it over the back. That is specifically mentioned in the installation test instructions. Sure you don't want it just behind the keel though that is presumably impossible anyway. After all most power boats attach their fishfinder transducer to the transom protruding an inch or so below the surface.
There is a limit on the thickness of the hull it can shoot through and no wood core. From memory of a few years ago I think it may be 1" but it is on the airmar site. I would check this and your hull structure rather than just rely on someone.
You may find that the lead is not long enough to go over the transom.
It is a bit of a pain to fit one depending on the boat because of the need to be clear of the keel and the angle of the hull. You may have flatter sections aft than I did. But it is not that bad once you figure it out.
I put a garmin in hull in a Pearson 424 where the hull was angled pretty good and 1+ inch thick (I think more like 1.25) and it worked very well to 800 feet
Sent from my iPad using Tapatalk
1 - 12 of 12 Posts
