Question: Why is my Balmar series 7 110 amp with AV-5 smart regulator only putting out 60 amps at max engine RPM?
I installed (myself) a new Leece-Nevelle (Balmar) alternator on my Yanmar 3YM30 engine last weekend. David at East Coast Batteries and Electrics in Ft Lauderdale built my system up to include the wire harness to plug and play into my existing engine set-up. We benched tested the system and it showed 110 amp output. He also programed the AV-5 for my battery system. His expertise and customer service was outstanding. He walked me step by step throughout the whole process. And his prices are the best I could find anywhere to boot.
I installed the system, triple checking all wire connections. This included the the new 4 Awg positive and negative wires to the engine starter and engine block ground. I had turned off the battery charger before starting the engine and use about 30 amps out the battery bank before testing the system. My XBM and the AV-5 only showed 40 amps going into to battery bank of 2X4D's flooded cells. I than went sailing for 7 hours draining an additional 90 amps out the batteries (I turned everything on). When I ran the engine at full power the most I saw was 60 amps coming out the alternator according to the AV-5 smart charger at 14 volts. At low idle - mid-range RPM I was only seeing 40-45 amps.
Before I start making phone calls my thoughts are seeing what you all have to say and if I have too compare it to what they are telling.
1. Is this normal?
2. Can the engine spin the alternator fast enough? I have 1/2 belt and the pulley on the new alternator is 2/1/2 inches vs 3 inches off the old one.
3. Since I don't have temp sensor for neither the battery or alternator does the AV-5 limit the alternator output?
Thanks for all replies
1. Is this normal?
