21 - 34 of 34 Posts
PD, OK, I think what you are saying is that the debris may have accumulated in the bowl during normal use and not the evaporation process? If so, might not draining the bowl from time to time help to get rid of some or all of the debris?I will let you know how the evaporation expiriment comes out, may take a while. I have used Berryman's B-12 fuel additive for years which is supposed ti absorb moisture? I have never seen any water in the bottom of my various fuel tanks. I will try another expiriment, put some gas in a container, add some water, then add some B-12 and see if the water goes away?
Dabnis
Dabnis
I did a study for Practical Sailor Magazine a few years ago. NONE of the additives had ANY material effect on e-10 separation. They may do other things, but they DO NOT prevent separation. Just snake oil. They did work, to some extent, on non-ethanol gasoline. However, some of the old "dry" additives have been proven to make separation in humid conditions worse! They were ONLY for winter use, to prevent icing, when the humidity is low. But the advertising didn't say that.
Yes, I suspect you were getting occasional e-10 separation. The best cure is to keep the tank full and the vent closed when possible.
I doubt draining the bowl is fast enough to remove any debris. Removing the bowl and cleaning every few years is very easy on some small engines (I've done it on my 3.5 Merc while the boat was hanging over the water on davits! I also added an in-line paper lawn mower filter.) and might make sense.
PD,
OK, half a can of gas, not sure how much ethanol is in it, the pump says it can be up to 10%, added half teaspoon of water and about half an ounce of B-12.
Upon stiring the mixture turns milky then clears, no water beading. After it sat for about an hour there was a very slight "line", no beading, in the bottom that went away with a slight stir. It would appear that with any motion at all the water has been absorbed by the B-12. The evaporization test is in progress but will take a while.
Dabnis
PD,
Upon stiring the mixture turns milky then clears, no water beading. After it sat for about an hour there was a very slight "line", no beading, in the bottom that went away with a slight stir. It would appear that with any motion at all the water has been absorbed by the B-12. The evaporation test is in progress but will take a while.
Dabnis
Not surprising. With e-10 at summer temperatures about 1.6 ounces of water will dissolve in 2.5 gallons, and what you describe is the way it looks. The moment you pass the threshold, ALL of the alcohol (about a quart) will come out in 10 minutes. B-12 (biodiesel) should have little effect, except that the biodiesel is less oxidativly stable than other 2-stroke oils (the biodiesel could be the problem).
A note of caution about runnig dry.
A two cycle engines needs the oil mixed with the gas to lubricate itself. Running the engine dry gives you that last moment without any lube in the engine for protection. Might not cause much damage but the cumulative effect and the dry cylinders made available for corrosion to take hold ought to be considered.
I should have been more specific "B-12" meant to say "Berryman's B-12 fuel additive" I checked the mixture today after it warmed up a little, can't see any trace of the water. So, I am wondering, did it evaporate from the top or is the water still in suspension in the gas?
Thanks, Dabnis
I run my carb dry if I'm not planning on using in within a week. I have occasionally forgotten to do so when distracted, and it has been fine over three outboards and 25 years that way. Plus, the garage flushes usually take care of that in the fall anyway. I think new gasolines are much more stable, and less prone to varnishing.
Unless I've run the carb dry, or switching tanks, I never touch the bulb. No need to.
Thanks, Dabnis
You won't see any water when you dry a sample; it will evaporate along with the ethanol as an azeotrope (Azeotrope - Wikipedia, the free encyclopedia). That is the thing about ethanol and water; they like each other far more than they like gasoline.
I.
May I respectfully suggest that you look at butyl cellosolve.
Dick
Dick
I was looking at the ingrediants of Berryman's B-12 Fuel Additive:
Toluene(108-88-3)
Methanol (67-56-1)
Acetone (67-64-1)
2- Butoxethanol (111-76-2)
Mixed Xylenes (1330-20-7)
Isopropanol (67-63-0)
Methyl Ethyl Ketone (78-93-3)
Curious as to what all that stuff is and what it does?
Thanks, Dabnis
Toluene(108-88-3)
Methanol (67-56-1)
Acetone (67-64-1)
Thanks, Dabnis
As it turns out, 2-butoxyethanol is very similar to cellosolve. Commonly used as degreasers (it is the smell you notice in Formula 409), these chemicals will help clean deposits in engines and carburetors, and they have some function as co-solvents, holding alcohol/water/gasoline mixtures together. They can also strip paint and destroy hoses and gaskets, even those formulated for gasoline and alcohols. They are relatively safe at the typical recommended dosage rates, though aggressive additives have been implicated in elastomer failures.
The fallacy is this; yes, it is possible to add enough chemical and soap to the fuel to hold the water in solution, but it takes a lot, not the small doses we are used to seeing in fuel additives. We did test 2 products like this. Typically, the required dose was as much as 20:1 (greater than the 50:1 2-stroke oil dose) and we were VERY uncomfortable adding emulsifiers in such large doses. Unless the additive manufacturer is prepared to run engine durability tests with a manufacturer and get the seal of approval, I think such treatments are risky and unwarranted. The risk to lubrication effectiveness is far too high.
PD,
Thanks for the reply. Berryman's recommends 1 oz per gallon. Do you think that is a "safe" ratio? I have been using it for years in off road motorcycles, outboards, snow blowers, generator and cars and have not had any fuel related problems except for the time I forgot to drain the carb on one of my outboards. However, your comments about lubrication effectiveness raises some concerns.
Thanks, Dabnis
PD,
Thanks, Dabnis
That's pretty typical, and it is 5-20 times less than additives formulated to absorb water. Sounds OK.
The reality is that most small engines die from other things than cylinder wear. Sailboat kickers die of corrosion and lack of use. Same with most snow blowers and chainsaws. We get sick of fooling with other non-use problems before real hours pile up.
OK, sounds good, I think I will stay with it. As mentioned earlier I put some water in gas, added some Berryman's addetive and the water became invisible, I think you said it evaporated, anyway it's gone from sight. I am doing the evaporation test mentioned earlier, half a coffee can of gas, surprised it evaporates so slowly. Thanks again for the info.
Dabnis
21 - 34 of 34 Posts
