Has anyone used an Angle Drill to hoist someone up the mast? If so, how big of an Angle drill? Is 20 volts strong enough for a 200lb man? Any thoughts?
I weigh ~150, I tried raising a 200 lb friend using the tiny mast winches on his Bristol and only succeeded in giving him an atomic wedgie, couldn't get his feet off the ground.It really depends on how big your winch is.
Sent from my SM-G981W using Tapatalk
This is true... and many jobs can / should be done by a boat owner. Part of owning a boat is maintaining, outfitting and repairing. In so doing you know your boat and are less helpless. And... there are no handy mechanics offshore.There's a point where some jobs must be hired out to pros.
Thank you Sander. I think I'm going to take a chance and purchase one. They have a 20 volt on Amazon for around $100.I have a Milwaukee right angle 1/2" chuck uses a lithium battery 18 volts I think. I use it in self tailing winches to raise the 440sf main... and I have used it to hoist wife up the mast in a bosun chair. Mast track needs to be clean and lubricated... No it doesn't just shoot the main right up. I don't need nor use for trimming sail.
I no longer have the strength to these lifts with manual winching.
Thanks TB. I $200 lbs. and its a hassle getting people to hoist me up.I weigh ~150, I tried raising a 200 lb friend using the tiny mast winches on his Bristol and only succeeded in giving him an atomic wedgie, couldn't get his feet off the ground.
He got a mast climber, it worked but that's a lot of effort for a big guy.
I'm going to purchase one and give it a try.I have a Milwaukee right angle 1/2" chuck uses a lithium battery 18 volts I think. I use it in self tailing winches to raise the 440sf main... and I have used it to hoist wife up the mast in a bosun chair. Mast track needs to be clean and lubricated... No it doesn't just shoot the main right up. I don't need nor use for trimming sail.
One of the members in my club has the mast mate and offered it to me. I'm keeping this as a second option, just cause I'm lazy and don't want to mess with taking down the main sail. If the angle drill doesn't work, mast mate will be the way I'm going up.Hi Coney Island Kid,
A few years ago someone on The Boat Gallery mentioned using this technique during a discussion about using the Mast Mate for going up the stick.
We use a Milwaukee 24v right angle drill with a winch chuck adapter. The first mate takes me to the top in a couple minutes no sweat. Also used in the cockpit when we are too lazy to crank winches. ;-))
As one whose wife swears she will never get on a sailboat with me, I keep an eye out for single-handed solutions like the Mast Mate or the ATN Mastclimber...![]()
Red
The job I have to do on top of the mast is not hard. It's just getting up there.There's a point where some jobs must be hired out to pros.
Where I'm at sailboat riggers and diesel mechanics are as available as unicorns.This is true... and many jobs can / should be done by a boat owner. Part of owning a boat is maintaining, outfitting and repairing. In so doing you know your boat and are less helpless. And... there are no handy mechanics offshore.
And I'm sure, at DOUBLE the cost! 🤣Where I'm at sailboat riggers and diesel mechanics are as available as unicorns.
Ahhh....but does it come with a battery and charger? That my friend is the question.Thank you Sander. I think I'm going to take a chance and purchase one. They have a 20 volt on Amazon for around $100.
Certainly going up the mast is not something to be taken lightly, but with the right equipment and preparation it isn't really a big deal.
