- Reaction score
- 2
The setup on my boat makes it difficult to put a zinc on the shaft or prop. There's not much shaft showing in front of the prop, and behind the prop there's little room between the nut and the rudder. A 2.5 cm thick shaft collar will fit, but underway the thrust the engine/flexible coupling shifts forward a little and the zinc rubs on the cutlass bearing.
I've ground the zinc thinner, and it helps but need to take another mm or two off.
My question is this..do I really need an anode? Everything down there is bronze. My boat has been on a cold freshwater lake since it was repowered 10 years ago and I'm guessing previous owners did without. Now that I'm in salt water I'd like a zinc to protest against electrolytic corrosion. The reason I'm doubting myself is that I had a talk last year with the owner of a 50 year old wooden boat with bronze shaft/prop and he didn't use a zinc. His claim was that the boat sitting in cool (salt) water on a mooring, far from any marina with shore power and similar metals made the anode unnecessary. His boat was out of the water, and his prop and shaft did look to be in very good condition. I have my doubts..am I missing something?
