1 - 20 of 25 Posts
I'm starting a project that I have posted a couple of times on, as i first saw the boat etc. and got some awesome advice, so figured I'd keep a good thing going :) I might end up talking to myself for 4 months, but it won't be the first time..
A little background.. I race on Wed nights on a 36 Bavaria, that is a beautiful boat. I have a powerboat and love the water (and a bit of a boat addiction) - another guy and I bought a sailboat last winter, 22 Starwind swing keel, and keep it at a marina at the beach, she's a beauty and we're having a great time now that the weather's warmed up, and learning alot ! SO-Another guy on the racing team had what he thought was a Flying Dutchman in his yard on a trailer, and said we could have it (he has to move and can't bring it) we're unsure if it is a FD, it doesn't really look like one, but one thing we're sure of, it came from Kent State Sailing Team and it's hull #383
So, a hull that needs paint (and then some) and two buckets of blocks, bolts and hardware, a couple of masts and a half dozen sails and that's all I've got.. we don't want to sail competitively, and we don't want to spend a ton of money on her.. we were unsure what to do, and after my first post with "where do things go" etc.. a guy told me to step the mast, slide the boom on, put on a sail, and figure out what needs to go where to move it..
and IF we have fun and want to continue with the project, then look at painting it, upgrading hardware etc.. (Awesome advice !!!)
So this is the thread where I'll ask a million questions, while figuring it all out..It's like Sherlock Holmes (more like Inspector Clouseau) - this is a teardrop shaped part, it must go here !!! and hopefully like the ride enough to pony up a few hundred bucks to paint her.. She certainly looks fast..
SOO, I've stepped the mast, and the shroud attachment is questionable at best, but the forestay is dead on, i have no idea how the Jib attaches to the mast, but it has a wirestay up the luff? the only place i can see where it would attach is angled downward with a slot in the center..last fuzzy pic..
So the plan of action for tomorrow, is to look at a jib and see how it attaches.. and float it (i live right beside a landing) and mark the waterline... to see mast rake etc..
If anyone has any idea what it is or has any words of encouragement let me know !!!
· Telstar 28
The jib probably doesn't attach to the mast at all. It is probably just hoisted on the jib halyard, with the tack attached to a fitting near the base of the forestay. Looks like a nice little boat in need of some TLC. Good luck.
Discussion Starter · #3 ·
I need to go check out some local racing boats.. I can't figure out how the Jib attaches to the mast, there is no halyard and a wire in the luff of the sail.. someone suggested to use the luff of the sail as the forestay, but that would be quite the predicament if a storm sprung up.. there are 2 holes with steel wire leading out that go back to locking tensioners.. I assumed one was for the forestay, and one was for the jib.. but the only attachment point on the mast that is at the right height for the jib looks like the claw end of a hammer pointed downward, with another below it ... does anyone have any ideas ??
The next problem is the shrouds.. we'll leave that description till tomorrow :)
· Midwest Puddle Pirate
The more I look at it, the more I think it's an S16 or one of it's close relatives. This page might help a bit.
Edit: what a PITA. I can't get the link to work correctly. www DOT geocities.com/sweet16fleet2/rigging.html
· Telstar 28
That's cause the keyword auto linking is picking up the word rigging and screwing it up... use TINYURL.com to fix the url so that it doesn't happen, like this:
LINK
http://tinyurl.com/m57hyz
· Francophobe
Unfortunately I don't think it is a Sweet 16. Two clues point me away from that. First, the hull on the boat in question is smooth going up the side, but Sweet 16 has a hard line almost like a chine along the sides
Second, the OP pics show a traveler which I cannot find in any of the pics of the Sweet 16.
It does look somewhat like a Flying Dutchman but all of the FD pics I have found show a flat deck whereas the boat in question has a slight cowl separating the foredeck from the cockpit.
Wish I could point out what boat it is but I am stumped
Discussion Starter · #9 ·
I agree, it might not be a Sweet 16, but one its close relatives.. the rigging diagram will help out tremendously though..
It is 21'9" long, almost 6' longer than the Sweet16..
I did manage to find a photo of it though : theRock
I even found the name of one of the people in the photo, and emailed her asking what kind of boat it was :) I'm a supernerd..
I'm sure it will eventually be figured out ...
· Super Moderator
Farr 11.6 (Farr 38)
That surely looks like a Flying Dutchman. The Flying Dutchmen were are between 19'10 and 19'11 inches measured on deck, and they are 5'10 wide. I am wondering whether you included the rudder in your length?
The little hooks are called Halyard locks, they were used with small metal ball fittings that were nicropressed onto the wire halyard (Forestay). You would hook the ball into one of those hooks and it would hold the wire at that position. Typically these were used with short wire halyards with light weight penants or no penants at all. In the case of no penant you would lean the boat over on her rail, lock the ball and then stand her up again.
The genoas were flown on a roller furler which used the luff wire of the jib as the forestay. I believe that there was a genoa halyard involved on older boats and some kind of below deck stay tensioner on newer boats.
Here is the official rule book that shows how they were set up.....http://www.sailfd.org/pdf/2006/fdcr2006letv2.pdf
Discussion Starter · #14 ·
RanAweigh, that's a pretty boat in the first pic!
The second link you sent did have a cowl on the front and that is the first pic of a FD i've ever seen with one !!
Very Interesting..
I'm off to race the big boat tonight, but I'll update her measurements etc tomorrow !!
Discussion Starter · #18 · (Edited)
definately missing spreaders..
need to talk to selden..
does anyone know of anywhere else to check ??
I'm also having trouble figuring out how to tension the side stays..
I found an article somewhere that suggested that they ran through 90deg bends, to the bow of the boat, then through a roller and a locking device on the front bulkhead..
Has anyone seen that in action ??
Our FD does have a roller in the inside of the bow, and lockers on the front bulkhead, but we assumed they were both for the forestay and jib halyard...
Discussion Starter · #19 ·
I have no idea why I can not find more info on this boat..
Considering it was an Olympic class, i figured there would be thousands of articles, used sails, parts, hulls, photos , ANYTHING>.
I'm a nerd and search pretty relentlessly.. but not much info..
Ebay has apparantly never sold one ??? WTH ??
Is there a name for this boat that I don't know about ??
1 - 20 of 25 Posts
