1 - 5 of 5 Posts
Discussion Starter #1 (Edited)
I am new to the sail boat world and needing help. I have found a boat local to me and can not find any identification markings on it. I have not climb into to see the interior. I do know its a lead keel and I have stepped it off and its around 28-30 feet. Can you help HELP!!!
That's a standard mid 70s-early 80s hull form, a shot from above with the cockpit and cabin visible would be more helpful. Has a 'santana'ish look to it but can't find a match.
Scrape the gunk off the transom and in the upper corners you might find an HIN code. That will help too. Should be 3 letters followed by a string of numbers.
I used sailboatdata to look up all the boats I was shopping. Good info.
Sent from my SM-G930V using Tapatalk
1 - 5 of 5 Posts
