I'm crushed. The 1980 Allmand 31 we just purchased may be about to be parted out. The damping plate exploded in the engine when the boat was moved from VA to the Northern Chesepeake. The marina was just out to look at it, and they say that the motor mounts were shot, most of the hoses in the engine should have been replaced, the prop shaft was misaligned and cutting through the hull, and the transmission is likely shot. The cost to repair everything will likely exceed the value of the boat.
I had the boat surveyed by someone who was recommended by two different marinas in that area. I can't believe he missed some of these issues.
