1 - 20 of 45 Posts
We always put on our foul weather jacket on first, followed by our harness/life vest. If you have fallen into the water with your foul weather gear, you know how heavy it is and impossible to move around. Your thought would be taking off your foul weather gear to save yourself, but your life vest is in the way. Taking off your Life vest is risky unless you are in calm sea.
Forward thinking, put on life vest first, and followed by foul weather jacket. You can lost your jacket any time you need if it becomes necessary.
Your comments?
Corsair 24
last time i was solo for brief stint down to santa cruz i had the harness under...felt great and I could layer and unlayer easily
Discussion Starter · #5 ·
If I fall off the boat with tether is on, with the wet heavy jacket I will only have very limited mobility and diminished strength. I will not be able to make it up to boat. I need to lose the jacket and pant to get back on the boat.
Discussion Starter · #7 ·
Good to hear. I have been doing this when I solo or on nite watch since lat year. I did the Safety at Sea training two years ago and found that with the wet foul jacket, I wouldn't make out.
In fact, I stop wearing life vest, but wear my safety harness. The inflated life vest will also hinder of my movement. I want to buy a manual inflate life vest. I don't like auto inflate knowing what I know now and how I will use it.
Administrator
Beneteau 393
Warmth.
If in a cold area maybe its better to keep the foul weather kit on under the life jacket.
But yes for getting out of it and onto the boat it would be more difficult. But my default method to get a MOB up is hoisting them on the main halyard.
Corsair 24
well for light cruising and stuff and light wether the teather just goes under the foulie jacket out the bottom if you will
for heavy weather and rain and crap its kind of unavoidable that it has to be over you...
the lighter and tighter fitting the better for me
there are definitely bad cumbersome and loose fitting tethers out there
Super Moderator
Interesting question. The type of life jacket would probably make a difference to how you'd think about it.
The inflatables come in several types, Hydrostatic, auto, auto manual etc. If you need to pull a tab to inflate, or in case it doesn't inflate, blow it up.. you'd probably want it outside. If you trust it to inflate, your Jacket better be extra sized to handle an inflated vest or you could compress your chest and restrict your breathing. In either case you'd want crotch straps.
The type 1's are pretty damn bulky, but they're the only one most likely to turn you up if you're knocked out. You'd probably Wear it outside IMO
Type II's and III's should fit under ok.
I agree with Mark..up here in the north..warmth is more important. Next to drowning, Hypothermia is the risk. You shouldn't move around unless you have to, just float.
Corsair 24
it just depends where you call home
here in central america underwear is optional its so damn hot
basically here id be in a tether and briefs and be happy jajaja
Warmth.
I'm old school on this sort of stuff, I suppose...
My default method is to concentrate on not falling off the damn boat to begin with... :)
It's worked so far, though I'm sure it's just a matter of time... Unless I get "hacked to death by a machete" some night while at anchor in the Bahamas for the want of a firearm, first...
Corsair 24
Yes that too. and when it rains there..you're putting on swim suits and taking sun showers ..not getting in to foul weather gear..
you got it
swing out the JOY dish soap and have a ball on deck! gett a full on rainwater rinse
that and filling up water tanks and all sorts of stuff if ut rains enough! jajaja
Corsair 24
jajaja
wrong thread man! you should post this on that other one...:D
Super Moderator
I hear a box of thumbtacks is a good alarm clock.. for a machete attack. Dunno if they work for zombies
Senior Smart Aleck
well for light cruising and stuff and light wether the teather just goes under the foulie jacket out the bottom if you will...
I lead the tether out the top of the zipped jacket. If you should fall overboard, you do not want the tether pulling you feet first, or pulling your jacket up in front of you. I agree with rockdawg - I want to be able to shed the outlayers, if necessary, in order to climb back on.
1 - 20 of 45 Posts
