- Reaction score
- 3
Many sailors put their boats bow-in a slip because they have trouble backing. The problem is partly due to prop-walk and partly due to panic.
You can use prop-walk to your advantage when backing into a slip.
If your boat backs to port, maneuver to a position with the bow pointing slightly to port and the stern aimed toward the piling that will be on your statboard as you back. The boat will straighten as you reverse your engine. The first problem is that the stern will continue swinging to port as long as you keep using reverse. The second problem is that you will panic as your stern threatens the boat on your port side.
Whatever happens, remember this, 'steer toward what you don't want to hit and shift into forward'. This will kick the stern away from danger on either side. Don't add power, just use the shift lever.
Dont bother to try to steer while backing (unless you are using speed for maneuverability). Why? Because in forward gear the prop is shooting water over the rudder which gives steerage. In reverse the prop is pulling water from all directions astern and the rudder is all but useless.
Continue backing and continue to use forward gear along with steerage to keep the boat aligned in the slip. When the boat is fully in the slip get an after-amidship springline onto a piling on the dockside and behind the boat. I use the winch to an aft piling because I can adjust the line with just a tug.
Put your fenders out and go into forward gear. Let the boat lay against the pier. Leave it in gear and steer port or starboard to align the boat in the slip.
Now, at your leisure, with the engine still in gear, secure the boat with breast and spring lines.
Note: I don't put fenders out until the boat is in the slip because they sometimes catch on a piling and spring the bow away from or into the pier.
With the boat stetn-in, your crew will no longer have to climb over the bow rail to jump down to a short finger pier. It's much safer.
Try this method on a calm day with an able crew aboard to fend when you mess up the first few tries.
Good Luck.
Captain Max on Foxglove
Good Luck.
