Hi all...I'm new here. Long story with important questions follows:
I recently bought a 1975 Santana 30 with I believe the original engine. Prior owner had her for 30 years and had the engine professionally rebuilt but I'm not sure exactly how many years or hours ago. Its not been used much at all the past few years, but I need to deliver the boat in the next couple of weeks for winter storage and that will include transiting the East River in NYC...so a healthy motor is required.
I'm not familiar with marine diesels (yet) so each use I've verified cooling water flow as shown by the PO. No functional gauges - tach, oil pressure and temp are all inoperable. Two engine uses ago I didn't see flow so I inspected the impeller and it looked good. Opened sea clock and water flowed well. Reassembled and observed water coming out with exhaust as PO advised was normal. As we were returning to mooring under power I noticed white smoke/steam building out exhaust...then motor rpm slowed by itself. I put it in neutral and the rpm came back up. Since we were close to the mooring and in a tight spot, I put it back in gear to get to the mooring. Engine slowed, then stalled and won't restart.
So far I have removed the thermostat (rusted mess), exhaust manifold (plugged with iron oxide and carbon) and the head (looks like it's a bit warped on the non - cam side and has been weeping seawater down the block for quite awhile). Pistons, valves and cylinders look great. No funny or bad noises. No water in oil and doesn't seem to be oil in the water.
Before pulling the head I could easily turn the flywheel through many revolutions by hand regardless of the decompression lever position. This scared me into pulling the head but there's nothing obviously wrong so far...????
Money and time are serious hurdles at the moment (but I know I'm not the only one in that boat :-D)
Thoughts????
Thanks in advance,
-Keith
Thoughts????
Thanks in advance,
-Keith
