1 - 5 of 5 Posts
Hi there! I have an original (1977) Barbarossa 4 main sheet winch and the ratchet just stopped working. I have not pulled it apart yet, as I am not sure where to start? :confused: has anyone had experience with this type of winch?
· Senior Moment Member
Don't know them specifically but I suspect there's a fastener of some sort at the bottom of the handle socket - screw head or Allen head or something. If you get REAL unlucky there will be an internal snap ring down there for which you will HAVE to buy long nose snap ring pliers.
That winch looks like it's never been serviced - probably the pawl is gummed up with dried grease or the spring broke. Neither are a major problem.
P.S. here's a cut & paste of an old post on lubing winches;
As far as winch lubrication goes, I'd like to add a bit of "against the grain" info here. I now exclusively use white lithium grease on my winches. I have tried everything over the years - water pump grease, insanely overpriced "winch" grease from the manufacturer, PTFE grease etc. etc.
The white lithium is actually a cream colour and has a consistency about like stiff yogurt. I currently have a cup of Gunk brand and it is specifically recommended for boat winches. You have to be sure to get some with this colour and texture. I have also seen "white lithium grease" that was much more like the usual grease you see - more of a dark amber colour and very stiff, like wheel bearing grease - DON'T use this stuff.
It goes on cleanly and stays clean - doesn't trap dirt like the other stickier greases. It also leaves everything freer - the winches turn noticeably more easily. Its lower viscosity than the other commonly used winch greases gives it these attributes. I've been using it for at least 20 years now and have NEVER had a spring or pawl or any other failure on a winch greased with it.
Here's the sacrilege - you can GREASE your pawls & springs with it. A light coating clings better than oil but doesn't cause the stiction that heavier greases would (and which is the reason for the conventional wisdom of oil only on them). This has the added benefit of quieting the winches - the pawls go tic tic tic instead of clink, clink, clink.
I grease everything quite heavily, reassemble the winches and rotate them several times, pop the drums off again and wipe off all the "squeeze out", then reassemble. That gives the exact right amount everywhere internally.
It has the added benefit of cleaning up easily when you strip the winches next time - no wire brushes needed to get the dried crust off things - everything rinses clean in solvent or diesel.
Only one lubricant needed for everything, including your throttle cables, shift mechanisms, steering cables etc. as well. A cup of it costs about $5 and lasts for about a decade - try it, you'll like it a lot.
As for PTFE greases (Teflon), a friend who was in the bearing business for decades said it should NOT be used on caged roller bearings. It is so slippery that the rollers tend to skid instead of rolling.
Harken (winches, and other sailing hardware) bought Barbarossa in about 1985. Call Harken to see if they still have the info (drawings/manuals) that you need.
Harken.com 262.691.3320
Discussion Starter · #4 ·
Thanks guys... with your advice I will see what progress I can make and report back :)
I'll swag there is a bolt down at the bottom of the winch handle socket. Remove this, then the outer case pulls up and off. Be carefull that the upper and lower bearings assuming you have them do not come off at the same time. I've had this issue a couple of time.
My 40's are and use the same parts as current Harken 40's.
Marty
1 - 5 of 5 Posts
