1 - 11 of 11 Posts
Discussion Starter #1
I stripped a thread in the boom this weekend, its a 10-24 thread and one of 4 screws holding a cheek block to the boom.
My go-to for thread repair is typically a heli-coil style insert. But in in a boom (or mast) I assume the insert would just thread itself right through (no bottom to the hole) ... is that correct?
So I'm wondering, what is the best way to repair this?
Is there any reason you couldn't use a blind rivet? I think it would provide a more robust longer term solution.. Most (if not all) of the hardware installed on my spars are done with good quality ss rivets (and Tefgel).
There is another option called Riv-Nuts. They're like a threaded pop rivet. You drill the over oversized to fit the size Riv-Nut that you need, put the Riv-Nut in the hole and then set it with a threaded mandrel. Once it's set you remove the mandrel and now you have a threaded hole.
Just remember the problem with dissimilar metals. Use some Tef-gel or Lanocote on the SS screw if you tap for a bigger size, or on the pop-rivet if you're attaching a SS cheek block with an aluminum pop rivet.
But any of the above suggestions are good ones, I think.
JV
Living the dream
I've used helicoils on the mast no problem. Lube with tefgel. They'll break the bolt before unscrewing. Don't ask me how I know!
Probably the Riv-Nut, unless that section of the boom is thick enough to tap in a heli-coil or other insert.
Either way I think I'd bed it in a little 5200 or epoxy, rather than using tefgel or another corrosion block that added no strength to the piece.
1 - 11 of 11 Posts
