Thought I would give a thumbs up to this product. Tuf-Enuf bilge cleaner. I've used their all-purpose cleaner for years and liked it.
We had some trouble with the float switch earlier this year. I though it was just gunked up from the winter. I cleaned it and it seemed to work fine. However, I return a week later and there was an inch or two of water collected across about 50 sf of bilge. In various compartments, under tanks, mostly inaccessible.
To make matters worse, not only do our dehumidifiers drain to the bilge, but so do the fridges. The latter is undesirable, but I'm not putting another thru hull in either. The fridge gunk rots and there is a film of mold or some sort of smelly organic growth on the top of the water I can see. Obviously, it is everywhere.
Coincidentally, I had purchased Tuf Enuf to try, but hadn't needed it yet. I poured in a half gallon and head out for an overnight. The next day, I used a shop vac to get it all out. Cleaner than it's ever been! The place smells like an orange grove. Best yet, it doesn't foam like every other detergent I've ever used. Therefore, it doesn't fill up the shop vac with foam and trip the overfill ball.
The bottle claims it has bacteria that eats dirt and grime, like a holding or septic tank treatment. That makes a ton of sense. Clearly it has orange oil. After fully cleaned, I added a very little to the bottom of my now clean bilge sump and a smal amount to a compartment I can't keep mast water out of. I'm going to be curious what happens throughout the week. I think the oil floats on top. Since the bilge pumps draws from the bottom, I'm wondering if it remains throughout the pumping cycle or mixes and goes overboard.
Either way, I was very impressed.
Amazon.com - TUF-ENUF BILGEG Natural Bilge Cleaner Gallon - Boating [email protected]@[email protected]@http://ecx.images-amazon.com/images/I/[email protected]@[email protected]@41MYFFbmNAL
