1 - 12 of 12 Posts
Hi all, I know this is probably a stupid question. I am installing a second, larger, bilge pump to handle real water issues (Rule 2000), to supplement my primary pump which is a 500 gph. My question is this: Can I run the discharge from my smaller pump into the sink drain thru-hull? It would shorten the hose run by a great amount. I know that it would require keeping this thru-hull open all the time, but are there any other issues that I need to consider? Of course I know the larger pump would exit in the normal fashion.
Feedback?
Thanks, Bill
We had a similar arrangement on a previous boat.. never really liked it though. As you've noted if the pump starts when the through hull is closed you have a hell of a mess.. and the bilge pump can overload the path overboard even with the valve open, and you'll end up filling the sink (and beyond). We added a valve immediately below the sink bowl to eliminate that issue.
But overall I don't think I'd install a set up like that again. Ours was done, I believe, for the same reasons you are considering - the short run of hose.
Old Gaffer
Montenido, I did exactly what you are contemplating and it works really well. The little Rule 600 gph pump with 3/4" hose discharges into the sink drain, and the 2000 gph through a dedicated through-hull. There is a horizontal check valve in the sink drain to prevent back-filling when heeled. I ran the 3/4" line up through a vented loop well above the water line.
How big are your cockpit scuppers?
I had a similar question earlier (see SailNet thread on gear-maintenance/44434-plumbing-2d-bilge-pump).
I had installed a second, high-capacity pump above the primary manual one and wanted to use a Y-connection to the existing through-hull. Idea was to avoid cutting a new hole in the hull.
Bottom line: I backed away from the Y-connection idea and instead emptied the new high-capacity, float-switch-activated pump right into the cockpit. Kept the smaller pump connected to the existing transom through-hull (above the waterline).
I love the idea. It's an alarm-clock solution. Now, if my feet get suddenly wet, :eek: I'm alerted to a Serious problem.
Midwest Puddle Pirate
The thing that jumps out at me about doing this is that you'll have the bilge pump pushing water out of a submerged thru hull. Would it be possible for a siphon to occur back into the bilge?
Here's what would happen to me: I (or anyone else) leave the stopper in the galley sink. The bilge pump kicks on and pushes a little water up past the stopper. The bilge pump kicks off and the stopper reseals due to a little bit of water on top. Now we have a siphon between the thru hull and the bilge a couple of inches lower. This causes the bilge pump to come on again and pump the water back out. The bilge pump cycles like this until the battery is dead. I find my mast sticking up out of my slip.
I'm sure everyone here knows these figures, but...
Rule 2000 = 2000 GPH, allow 50% efficiency (very generous, 25% more realistic.) due to hoses etc. = 17GPM = 1000GPH.
I" hole 3' under the waterline (tru hull hose breaks off etc.) = 34GPM = 2040GPH
4" hole 3' under the waterline (ding a container/reef etc.)= 544GPM = 3,2640GPH = block the hole or its swimming stations.:eek:
Figures from Calder. Worth reading P 219 of his Cruising Handbook (as well as the rest of the book). Sobering stuff.
Interesting!!!!
Bottom line: I emptied the new high-capacity, float-switch-activated pump right into the cockpit. Kept the smaller pump connected to the existing through-hull. I love the idea. It's an alarm-clock solution. Now, if my feet get suddenly wet, I'm alerted to a Serious problem.
I like this idea too. Just two questions? How much water would make its way down below if the cockpit took a big wave? How high is the outlet above the bilge pump, it would be worth calculating the efficiency drop.
I also plan to add a mother of an alarm bell on a float switch.
The short of it, It is a bad idea.
You are pushing you bilge water against the surface tension of the water of submerged the thru=hull decreasing the out put of bilge pump.
You can have a siphon start and fill the boat. Putting a check valve in the line again reduces the out put of the pump.
You want the thru hull to be above the water line even when the boat heels and try to make the hose run as short and straight as possible.
Bubb2 is correct. Although with a small pump operating at a reduced rate, you might get away with it for years, in the long run, connecting a bilge pump to an underwater thruhull is a disaster waiting to happen.
There are a few reasons for the problem, the most fundamental of which is that a thruhull into the water (under water) creates a tremendous restriction thereby severely reducing actual pumping rate regardless of the pumps' rated capacity - in essence, you would be wasting your money putting in a large capacity pump on a system that restricts it.
Exaggeration for effect - you try pumping 2000gpm into a hose already partially full (as it is below the waterline) and then into a body of water resisting flow by the head pushing up against the thruhull.
In addition, the possibility of a siphon is very real creating a problem that should never exist. simply installing a backflow valve is a bad idea as it can fail without you knowing it and can also easily become clogged without you knowing.
On emptying the emergency bilge pump into the cockpit
gtod25,
1. Each of the two cockpit scuppers are three times the diameter of the inlet from the new, higher bilge pump. And that inlet through-hull is mounted in the footwell about five inches above the cockpit floor. So, if we were to get pooped and the footwell completely filled, there'd be some minutes in which the 1-1/8-in.-dia. hose back to the pump might act as a third drain. I'm betting that pump would impede flow into the bilge.
2. The cockpit outlet is about 4 ft. higher than the new bilge pump. No, I didn't do a calculation, but in tests there seems to be no problem with flow.
Retired and happy
I tnever fails to amaze me how an apparently simple question generates such an interesting and varied thread. It is one of the wonders of SailNet, I guess. :)
A couple of points to add to the debate.
I can entirely understand why there is a reluctance on everyone's part to install new thru-hulls below the waterline. However, given that a bilge pump outlet is above said line of water, then baulking at adding a necessary outlet seems unnecessarily cautious. :confused:
Both ideas touted on this thread as alternatives (ie use sink drain or discharge into cockpit) seem counter-intuitive (OK, OK, damned dangerous) to me.
Either a separate outlet for each pump, or a Y connector feeding into a big enough outlet for both would be the way to go, IMHO.
Stuart
Discussion Starter · #12 ·
Great Info Folks!
Thanks to all who have voiced their opinions. Some very good points have been raised. I will run an additional thru-hull for the bigger pump above the water line. I have also bought a high-water alarm that will be wired with the new pump. I don't really want to jump every time the small pump operates, but I definitely want to know if the big one goes on. The switch for the larger pump will activate at a higher water level than the primary pump.
Thanks again for the great tips.
Smooth sailing, Bill
1 - 12 of 12 Posts
