Hey,
Here is the maintenance log for my old O'day 35. I bought that boat in 2006 and sold it in 2014. It's in reverse chronological order.
Some details removed for privacy
Hope it helps
1986 O'Day 35 Day To Remember
documentation number
MMSI number:
2014
July 11 Bob takes boat from from Mt. Sinai.
July 3 Sold to Bob $25,500
May - moved from MSYC Slip to Mooring and put into service
2013
11/20 winterized engine raw water.
11/16 Winterize how water side (bypass). Remove headsail and dodger
11/10 Change engine oil and filter. Winterize fresh water system (head, cold side). Need to winterize engine and hot water lines.
10/20 100% jib repaired $180 for new sun cover and pendant. %150 genoa repaired - $350 for new leach panel and sun cover
8/5 New lazy jack lines. 140 UK Genoa repaired (torn leetch), New spreader ends. $300
7/10 Clean decks
7/3 Install new deck stiffener / tie rod. $90 from Rudy at D&R Marine
7/1 - costs: $6200 for XXXX - new rigging, installation of rub rail, repair of transom, installation of Furlex, etc.
$1800 to OMBY - $550 to paint, rest of haul, step / unstep mast, pressure wash hull,etc.
6/28 I sand and varnish toerails
6/24 DTR launched. JB tunes rig. Sails bent on, wires connected. Boat ready to be sailed.
6/22 I refinish (varnish) companionway, handrails, eyebrow. Toerail cleaned and lightened
6/21 James completes rub rail and holder. Transom repaired
6/21 Sail cover repaired by XXXX
6.18 OMBY applies bottom paint (Pettitt SR40)
6/17 new Zinc on prop shaft
6/15 Apply poliglow
6/12 Use poliprep to remove old poliglow. wet sand port boot stripe. Rig work: install new spinnaker halyward and flag halyards. Clean prop, sand, paint w/ zinc prop paint.
6/10 Jib and sail cover to Wedekin for repair
6/7 Jim B removes rub rail and holder. Removes old standing rigging.
6/6 Boat hauled. Rig down. Hull power washed
6/4 take sails down, move boat to old man’s, boat hauled for work
5/20 paint knot / log paddle wheel and install
5/15 bleach all interior compartments, scrub, rinse
5/1 - scrub bottom from dock - it’s pretty bad
4/20 - commission fresh water system
4/14 - move boat from Old man dock to mooring
3/22/13 - New spinnaker halyard- Cajun XLS (not installed)
3/10/13 Order new furler - Selden Furlex 200S. $2800 to XXX
2012
12/11 Change oil, oil filter, and fuel filter (R24S 10 micron)
11/27 James installes new lifelines
11/19 R+R Bent stanchions and stanchion bases with XXX
11/18 Move DTR to Oldman’s dock. Winterize fresh water system.
November - DTR is damaged by super storm sandy. See ‘Hurricane’
October - change fresh water diverter valve
August - new Main sail from UK $2500
6/1 Move boat to dock and take care of water system. Boat can be sailed.
5/31 Put sails on and tune rig.
5/30 Boat is on mooring (moved by Old Man). Lauren I do put boom on, run rigging and connect mast wiring. Too windy to put sails on.
5/15 Boat is ready for launch. Old Man can’t launch until Monday 5/21 and we are on vacation from 5/22 to 5/29.
5/15 pick up mainsail and dodger from Wedekind. $250 for mainsail repairs (leech, batten pockets). $275 for dodger repair (new window and zipper stiching).
5/14 repair mast wires for anchor light and steaming / deck light
5/12 poliglow stb side. install new batteries (Costco 27DC 115 AH, 750 MCA), wash decks, paint prop
5/11 poliglow port side
5/6 paint bottom (SR 40)
5/5 rig check. Need to repair anchor light wiring
5/4 Clean hull w/Poliprep. Clean bottom. Hull is ready for PiloGlow and bottom paint. Test run engine, runs great. Batteries are old and shot.
4/16 R+R shaft Zinc. Service all boat winches (not mast winch)
4/14 Sand Bottom Paint - complete
3/28 Sand bottom paint. Starboard front half complete.
3/23 Sand bottom paint. Port side complete (except for under jack pads)
3/21 Sand bottom paint. Completed about 25% (port rear half)
3/17 rewire - new jumper from ignition to glow plug. New jumper from glow plug (hot side) to start switch. Clean start switch solenoid wire (yellow with red stripe). Clean fuse in that line. Run additional glow plug power line and clean glow plug connections.
3/3 install new glow plug switch
2/21 install new bird spikes on spreaders
2011
12/15 - removed wind instrument -checks OK. Broken wire from mast.
12/4 boat covered
11/19 boat winterized and gear brought home
11/14 boat hauled
11/13 change oil and filter (3879 hours)
11/9 last sail. Solo
6/15 re-seal exhaust flange to prevent water coming in when motoring
6/12 new jib sheets (Cajun XLS)
5/26 headsail leach and foot line replaced
5.20 new lazy jack lines
5/11 boat launched
5/3 paint prop with antifoul
5/1 clean, poliprep, poliglow hull
4/23 scrub bottom with stuff brush to remove dead paint and expose new paint
4/22 Replace STBD port line clutch, Repair instrument mount, new prop shaft zinc
2010
11/13 Unload gear for winter
11/10 change oil. Boat hauled for winter
11.6 Last sail. With Mark, good breeze, great trip
6/12 install new water heater, new engine water pump, new thermostat
($240 for water heater $100 for water pump, $20 for T Stat)
655 remove engine water pump
5/21 Remove Hot Water heater
5/12 Hot water heater is leaking and needs to be replaced.
5/7 Water system commissioned, 2 new lights installed. All mast wired connected. Boat ready for the season
4/26 move boat to mooring. Put boom on. Engine ran hot – bled 3 times. Better?
4/23 boat launched (not in yard, have not heard from OMBY)
4/21 finish poliglow, prep for launch
4/20 Clean topsides, poliglow starboard side
4/19 paint bottom (SR 40 entire family)
4/15 Clean, lighten, oil teak. Test run engine (raw water hoses were reversed). Engine started and ran great. Wash topsides
4/14 wash and wax decks
4/7 Rudder installed. Wire rope is not run correctly
4/1 install new water pump, HX, drain and add new coolant
3/24 finish sanding port
3/17 finish sanding stb side, do ½ of port side
3/9 sand stb ½ of boat w/60 grit
2/25 New shaft (1” X 49”), coupling, packing box hose, clamps, etc.
2/5 Clean engine compartment and bilge
2/5 New Cutless beating (OMBY) - $1000 for all
1/20 January - Prop shat removed, cutless bearing removed. Shaft log removed (OMBY)
Heat exchanger removed, cleaned $75
Walts Radiator 928 1220
807 Hallock Ave
Port Jeffrsn Sta, NY 11776-1220
2009
December – drop rudder (remove quadrant)
11/16/09 Boat hauled
11/16 Change oil and filter, 8 gallons diesel
12/15 remove rudder
11/20 boat hauled
May: New main and jib halyards (Yale Aracom T)
Spring - Pettitt Ultima SSA
2008 Work
11/22 – cover boat, connect solar power
11/10 – winterize hot water side (blow out lines)
11/8 Winterize – remove sails, winterize cold water (drain hot water, need to blow out HW lines). Winterize head and holding tank, bring home electronics, remove impeller (blades cracked).
11/6 Boat hauled
11/1 Change oil. Add 5 gallons of fuel. 3727 hours
8/6 - 15 gallons of fuel. Scrub boat bottom
7/25 - engine doesn't start (does not turn over). clean all wiring connections
July - new exhaust system after NYC trip (hard pipes only, not waterlift muffler)
5/08 New headsail – 140% UK Passagemaker $3000
4/26 –Engine doesn’t start, replace Facet fuel pump
4/25 - Launch day
4/08 bottom done (fair keel, barrier coat, bottom paint - Pettitt Hydrocoat), poliglow
3/08 Sand bottom, keel.
2/08 Boat bottom soda blasted. Don at All Surface Soda Blasting. $1700 for everything.
He did a great job.
2007 Work
12/3/07 send Datamarine Wind Machine to DMI Inc. for repair
11/07 - start bottom paint removal
11/1/07 Boat hauled
10/07 change oil, filter, air filter, tension alt belt - 3685 hours
9/07 change macerator
9/07 tighten stuffing box, clean bilge
7/07 Repair starboard winch
6/07 Service winches (lose shaft and bearing overboard). New gears in port lazarette
4/07 New jib sheets, remove old name, new plow anchor, new mainsheet blocks and routing of sheet, install new name
3/07 Change engine oil, filter, fill fuel tank, fill propane tanks, new propane lines, repair glow plugs (wiring bad), coolant, fuel filters, engine zinc, refrig pulley and belt, radio installed, bilge pump re-wired, 12V meter installed
1/07 new house battery
See on Yachtworld. Listed at $38,900 make offer 11/06/06 for $30K. Offer is rejected, increase to $33K, which is accepted. See boat 11/10 and leave deposit. Survey scheduled for 11/17
Purchased 11/27/06 from XXXXX $33,000
Warren Trafton broker.
Barnaby Blatch Surveyor
Jack Neades Delivery Captain
Costs
$44 X 2, + 2 X 2 for trip to see boat 11/10
same plus $595 (survey) $650 (Haul) on 11/17 for survey
$200 car rental, $300 XXXX, $50 (ferry) for delivery
Delivery was 11/27/06 - Newport to Noank
11/28, Noank to Mt. Sinai
