1 - 12 of 12 Posts
I am looking at a late 70s j/30. I like the j/30 because the length is perfect, my slip can't go longer. I want a boat I can cruise the lake with my family. I want to club race and we have a lot of light air in the summer when most of the regattas are and I want a boat that does well in light air. The idea price would be about $15,000 us or less :) althought the j/30 tends to be more :(
Can anyone else think of a similar boat that I should consider that will fit these parameters.
Thank you in advance!!!
Not sure what area you're in, but the Aloha 30 is another frac rigged lightweight boat (Ron Holland design), the Laser 28 (Farr) is a bit smaller but also of the frac/light school. Both could provide the things you seek - though perhaps slightly above your "ideal" budget.
Discussion Starter · #4 ·
The J/29 as I understand it is a similar boat to the j/30 with a lower cabin top and no inboard diesel (lighter)
As I have the family cruising requirement I think the j/30 would be closer to what I was looking for but the other I will look into.
Thank you for the suggestions!!
Yes, the J29 is a lower freeboard version of the J30 hull, different deck and was offered in a masthead and a frac version. Not really a family cruiser, esp compared to her predecessor.
Would you consider a Tartan 30?
One of the things I like about the T30 is that some of them were configured with twin (port/starboard) quarterberths, which I think is a nice arrangement for family sailing.
J/30 isn't really known as a light air boat, but all things are relative. It depends on what kind of boats you're racing against. They get killed by lighter boats with higher SA/D ratios in very light air. They do well in 15 and above. But they have a pretty unbalanced rudder and in those conditions it can take a strong driver or two hands on the tiller to keep tracking. I suspect that any J/30 you find under $15k will be in need of some recoring, particularly around the transom and starboard rear quarter, and deck around the chainplates. I really like the J/30 interior.
You can get a great Tartan 30 for $15k, and they are very nice boats. However, in my area you wouldn't find anyone to race against in that rating band (~168), except J/24's, which are a totally different type of boat. I was looking for something similar to your needs and ended up with a Laser 28.
Pearson Flyer. Though only made for a couple years, there's always a couple out there for sale. Like the article says, it has "Undeniable appeal."
Two other choices:
Cal 9.2 - better cruising ammenities and cheaper than J30 but rates slower (PHRF about 172)
Frers 30 - good cruising ammenties but more expensive and rates a bit faster (PHRF about 129)
Forget the J29 if headroom below is an issue.
1 - 12 of 12 Posts
