1 - 4 of 4 Posts
Hello all.
I have an rk20 and I am not sure if the pulley on the boom is correct. Could someone help me find the correct block I need for the boom? It is a single pulley and for some reason I think it's suppose to be a double to go back through to the clan cleat.
Thanks.
El,
Not sure about you boat specifically, but a single block with becket on one end and a fiddle with cam cleat on the other should do. I attach mine with Wichard snap clips for quick rigging. Working load limit is 880 pounds but that's fine for a 25 footer.
Don
Barquito
If there is a double at the other end, you will need at least a single with a becket, or a double on the boom end. You are talking about the main sheet? It think for a 25' boat you will want a 4:1 main. So a fiddle block on each end.
1 - 4 of 4 Posts
