1 - 3 of 3 Posts
billybee41
Discussion Starter #1
I bought a 1994 Hunter 29.5 about 4 years ago. It has an optional retractable spinnaker pole that was not rigged when I bought the boat. I have it rigged so it is useable, but it is not right. In the manual it has a page that shows the pole but a note says "for pole detail see DWG #H29D2020". Does anyone have that drawing or a hunter 29.54 with the spinnake pole?
It was a very uncommon option. I tried to find one when I bought my boat in 2018, but wound up with one that did not have the kit. I've poked around trying to find one without luck. I've also looked at all the drawings I can find, have seen the reference to that one, but never found it.
Probably have better luck asking the question at the Hunter Owners forum. Would also suggest that you might refer to it as a retractable BowSprit .even if Hunter referred to it as a retractable spinnaker pole which is a bit confusing. Might get more responses that way Does the pole not extend fully or is it collapsing under load?
1 - 3 of 3 Posts
