I need it. I've been using a wretched painter's lamp via shorepower as my main cabin light for the 2 years and counting that I've been dockside. Sure, all the berth lights, LED strip lights, and even small salon table overhead light make for nice mood lighting and I can even cook (as long as I don't need to read a label or recipe!) and perform most of life's basic tasks by them, but it's still a ******* cave in here without that painter's lamp. Sometimes I just want to to be able to read, or splice a line, or read a label without have to grab the headlamp or position things just the right way under a fixture.
What solutions do you have, or have you seen, for really good cabin lighting? I don't know how room brightness is measured, but I know I've never been on a small-medium cruising sailboat that had lighting that was anywhere near on-the-grid-like brightness.
Yes, boats use batteries, and the builders know that no new buyer will be aboard after dark to complain about lighting until after the sale.
But I don't see why I should have to slowly turn into a mole just because I'm on a boat.
I replaced the dome light bulbs with LED clusters maybe 8 years ago. A significant improvement. Still not as much as I would like.
I have recessed area lights in the galled and behind one setee. I converted them to LED also, again helps.
My Wife is part bat and doesn't like bright lights, I can find reading stressful, especially a small font. Really small font, like the fine print on a can, may require a flashlight assisstance.
Bottom line, for us the LED bulbs were sufficient but not great.
Also we have a lot of white walls with mahogany trim, Some boats have a lot of woodwork which doesn't help.
You might have add more LED dome lights, wall lights, or use a temporary LED work light. If the head liner is light colored bounce the light off of it. Boat interiors are dark and tend to not reflect light and make the interiors "dark" or as some say,,, cosy.
You can get some pretty bright LED head lamps w/ magnifying for close work. Look on Amazon
with the perfect amount of illumination for trailers, RVs, or boat cabins, TDL series 5.5” Round LED Dome Light maintains a low profile frame. While clear dome polycarbonate lens distributes light and protects LEDs, white ABS housing gives the surface mount fixture a clean finish. Power switch...
LuxBar Linear LED Light Bars are an extremely versatile solution for both automotive and indoor lighting needs such as cabinet lighting, under-cabinet lighting, interior vehicle lighting, bookshelf lighting, police/emergency vehicle task lighting, footwell lights, and trunk/cargo lights. The...
www.superbrightleds.com
the dome lights are even brighter now that ive put the proper headliner in the boat, more reflections with all the lights on, even V berth and aft cabin and heads, i'm still drawing less than my incadecent running lights, maybe 3 amps, and each dome light has a switch on it.
The problem with the new high lumen LEDs is usually the designs... they are no really compatible with "traditional" boat interiors. My boat had OEM brass framed domes. Similar designs are available in polished chrome of stainless.
Or... you can re lamp the OEM fixtures with LED lamping... which is hit or miss until you get the right color balance and output.
My salon has a single dome light... two in the galley and one in the nav station. In addition it came with 4 bulkhead fixtures. All domes were re lamped with LEDs a 2nd LED dimmable fixture which can be also blue was added to the nav station (quite bright). Headliner is white gelcoat GRP the rest in teak and the upholstery is navy blue. Bright enough... but for detail work you need task lighting or a work light. Something like this:
Buy WF 36W LED Work Light Magnetic Base Mount Portable LED Light Flood for Car SUV Boat Bar Truck Driving Lamp Fog Lights: Driving, Fog & Spot Lights - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
I had the same problem and have improved things a lot by converting to LED’s. I had a bunch of those fluorescent fixtures that are about 10”x2” and don’t work half the time. I replaced all of them with this:
Lumitronics RV LED Lights Interior – Soft & Cozy Warm Light - Camper Ceiling Light Fixture 12 Volt LED Lights for RV Interior with 3-Way Switch for RV Lighting (1-Pack)
1-Pack
$11.99$11.99
FREE Delivery
Sunday, Mar 14
Sold by Northbay Products and Fulfilled by Amazon.
I chose them because they’re pretty low profile and about the same dimensions as the fluorescent lights they replaced. They are very bright and I can actually see what I’m cooking now. I also replaced the big fluorescents in the engine room with these and the heat hasn’t bothered them.
For the dome lights I got some little flat squares of LED’s that have about 3” wires leading to a plug that twists into where the old bulb was. But part of the problem with the bulbs besides being too dim, was that the contacts on the bulb would corrode and need to be cleaned or at least jiggled. So, I removed the socket from my dome lights and cut the bulb shaped plug on the LED squares off and crimped on those little round plugs on the wires which make a much better connection so no more flickering. The LED squares are about 2”x2” and just lay on the dome lights glass dome. LOTS more light and the way I have them semi-hard wired in, are very reliable.
Not sure whether you have experience working with LED’s but unlike incandescent bulbs, some LED’s are sensitive to polarity so before you permanently connect the wires, check to see if the light comes on and if it doesn’t, reverse the polarity and try again.
I think the issue is how much power is dissipated by the ballast, and I can't seem to find a figure on that. Anyone know?
Related Threads
1.7M posts
173.8K members
Since 1990
